- 积分
- 92323
- 明经币
- 个
- 注册时间
- 2005-3-31
- 在线时间
- 小时
- 威望
- 金钱
- 个
- 贡献
- 激情
;;;La为图层名 (defun Layer_zdsb (La / sel make_point_list n mn en entype pt1 pt2 pL sel k p1 p2 enlast ensel) ;;;=============================== ;;;表操作函数 ;;;判断点 p1 是否在点集PL中,是返回T ,不是返回nil,a为精度 ;;;例 (IsInPointList '(1.0001 1.001 0) '((1 1 0) (2 1 0)) 0.001),返回T (defun IsInPointList (p1 PL a) ;(setq n (length PL)) (if (member t (mapcar '(lambda (b) (equal p1 b a)) PL)) t nil ) ) ;;;取出图元索引i对应的值 (defun dxf (ent i) (cdr (assoc i (entget ent))) ) ;;;取圆弧的起点、终点。中点 (defun arc_3point (a / cenp radius STP ENPmp arcmidpoint) (setq cenp (cdr (assoc 10 (entget a)))) (setq radius (cdr (assoc 40 (entget a)))) (setq STP (vlax-curve-getPointAtParam A (vlax-curve-getstartparam A))) (setq ENP (vlax-curve-getPointAtParam A (vlax-curve-getEndParam A))) (setq arcmidpoint (polar (polar stp (angle stp enp) (/ (distance STP ENP) 2.0)) (angle cenp (polar stp (angle stp enp) (/ (distance STP ENP) 2.0))) (- radius (distance (polar stp (angle stp enp) (/ (distance STP ENP) 2.0)) cenp)))) (list stp enp arcmidpoint) )
;;;根据选择集中的line、arc、circle,生成点集 (defun make_point_list (s / PL) (setq n 0 PL '() mn (sslength s)) (repeat mn (setq en (ssname s n) enType (dxf en 0)) (cond ((= enType "LINE") (setq pt1 (dxf en 10) pt2 (dxf en 11)) (if (not (IsInPointList pt1 pl 0.00001)) (setq pl (cons pt1 pl)) );if (if (not (IsInPointList pt2 pl 0.00001)) (setq pl (cons pt2 pl)) );if ) ((= enType "ARC") (setq pt1 (car (arc_3point en)) pt2 (cadr (arc_3point en)) ) (if (not (IsInPointList pt1 pl 0.00001)) (setq pl (cons pt1 pl)) );if (if (not (IsInPointList pt2 pl 0.00001)) (setq pl (cons pt2 pl)) );if
);cond (setq n (1+ n)) );repeat (setq pl pl) );make_point_list ;;;此处SEL选择集可自行修改为命令行选择代码 (setq sel (ssget "x" (list '(0 . "line,arc,circle") (cons 8 La)))) (if sel (progn (setq Plist (make_point_list sel)) (setq enlast (entlast) ensel (ssadd)) (setvar "CLAYER" la) (command "_.boundary" "a" "b" "n" sel "" "" ) (setq n -1 mn 0 k (length Plist)) (repeat k (setq p0 (nth (setq n (1+ n)) Plist) mn n) (repeat (- k n 1) (setq p1 (nth (setq mn (1+ mn)) Plist)) (setq p2 (midpoint p0 p1)) (command p2) );repeat );repeat (command "") (while (setq en (entnext enlast)) (setq enlast en) (ssadd en ensel) );while (command "erase" sel "") (setq ensel ensel) );progn nil );if ) | 红色代码有误,已做修改!!!
共1人打赏
