这是老南方高人的高作,有点像photoshop里面得选择功能,但不知道为啥不好用了。请高手指教 AutoCAD VBA函数---选择闭合轻量多段线内的实体 Public Sub mSelectByPolyline() '选择闭合轻量多段线内的实体 Dim sSet As AcadSelectionSet Dim intCnt As Integer Dim strInfo As String Dim objPL As AcadLWPolyline Dim objEnt As AcadObject Dim pnt As Variant Dim objPnt() As Double Dim i As Integer On Error Resume Next Redo: ThisDrawing.Application.ActiveDocument.Utility.GetEntity objPL, pnt, vbCr & "选择闭合的轻量多段线:" If CheckKey(VK_ESCAPE) = True Then Exit Sub End If If objPL Is Nothing Then GoTo Redo End If If TypeName(objPL) <> "IAcadLWPolyline" Then GoTo Redo End If If objPL.Closed = False Then GoTo Redo End If Retry: strInfo = ThisDrawing.Application.ActiveDocument.Utility.GetString(1, vbCr & vbCr & "是否选择与边线相交的实体(Y/N)?") If CheckKey(VK_ESCAPE) = True Then Exit Sub End If If strInfo <> "Y" And strInfo <> "N" And strInfo <> "y" And strInfo <> "n" Then GoTo Retry End If ReDim objPnt((UBound(objPL.Coordinates) + 1) * 3 / 2 - 1) For i = 0 To ((UBound(objPL.Coordinates) + 1) / 2 - 1) objPnt(3 * i) = objPL.Coordinates(2 * i) objPnt(3 * i + 1) = objPL.Coordinates(2 * i + 1) objPnt(3 * i + 2) = 0 Next i intCnt = ThisDrawing.SelectionSets.count While (intCnt > 0) Set sSet = ThisDrawing.SelectionSets.Item(intCnt - 1) sSet.Delete intCnt = intCnt - 1 Wend Set sSet = ThisDrawing.Application.ActiveDocument.SelectionSets.Add("ENT") If strInfo = "Y" Or strInfo = "y" Then sSet.SelectByPolygon acSelectionSetCrossingPolygon, objPnt DelEntFromSSet objPL, sSet Else sSet.SelectByPolygon acSelectionSetWindowPolygon, objPnt End If If sSet.count > 0 Then ThisDrawing.Application.ActiveDocument.SendCommand Chr(27) & Chr(27) & "SELECT" & vbCr & axSset2lspEnts(sSet) & vbCr & vbCr End If End Sub Option Explicit Public objPicked As AcadObject Public Const VK_ESCAPE = &H1B Declare Function GetAsyncKeyState Lib "user32" _ (ByVal vKey As Long) As Integer Function checkkey(lngKey As Long) As Boolean If GetAsyncKeyState(lngKey) Then checkkey = True Else checkkey = False End If End Function Public Sub DelEntFromSSet(ByVal ent As AcadEntity, ByVal sSet As AcadSelectionSet) Dim objCollection(0) As AcadEntity Set objCollection(0) = ent sSet.RemoveItems objCollection End Sub '#39; ת»»¶à¸öͼԪµÄº¯Êý 从vba界面拷贝过来的,汉字乱码了,不知道为啥。 Public Function axSset2lspEnts(ByVal sSet As AcadSelectionSet) As String Dim enthandle As String Dim strEnts As String Dim i As Integer If sSet.Count = 0 Then Exit Function enthandle = sSet.Item(0).Handle strEnts = "(handent" & Chr(34) & enthandle & Chr(34) & ")" If sSet.Count > 1 Then For i = 1 To sSet.Count - 1 enthandle = sSet.Item(i).Handle strEnts = strEnts & vbCr & "(handent" & Chr(34) & enthandle & Chr(34) & ")" Next i End If axSset2lspEnts = strEnts End Function
