查看: 2658|回复: 4
定时提示
发表于 2010-2-4 13:35:00 | 显示全部楼层 |阅读模式
能不能定义一个timer,每隔一定时间在命令行写入时间实现报时功能呢?我尝试写过一个,但是timer事件里面取不到editor
发表于 2010-2-4 18:46:00 | 显示全部楼层
你的代码?试下文档加锁
 楼主| 发表于 2010-2-5 00:06:00 | 显示全部楼层
写一段利用timer的Elapsed事件在命令行里写一些信息的代码看看
发表于 2010-2-5 10:55:00 | 显示全部楼层
editor试过了,有问题,呵呵
Com调用的方式还可以,不过命令提示会消失掉
  1. using System;
  2. using System.Collections.Generic;
  3. using System.Text;
  4. using System.Threading;
  5. using Autodesk.AutoCAD.ApplicationServices;
  6. using Autodesk.AutoCAD.DatabaseServices;
  7. using Autodesk.AutoCAD.Geometry;
  8. using TlsCad.Trans;
  9. using Autodesk.AutoCAD.EditorInput;
  10. using System.Reflection;
  11. namespace TlsCad
  12. {
  13.     class Work
  14.     {
  15.         public Document _doc;
  16.         private object _acUtility;
  17.         static Type _acUtilityType;
  18.         private Timer t;
  19.         private bool m_Starting = false;
  20.         public Work(Document doc)
  21.         {
  22.             _doc = doc;
  23.             object acDoc = _doc.AcadDocument;
  24.             Type acDocType = Type.GetTypeFromHandle(Type.GetTypeHandle(acDoc));
  25.             _acUtility = acDocType.InvokeMember("Utility", BindingFlags.GetProperty, null, acDoc, new object[0]);
  26.             _acUtilityType = Type.GetTypeFromHandle(Type.GetTypeHandle(_acUtility));
  27.             t = new Timer(DoWork, null, 500, 3000);
  28.         }
  29.         public void DoWork(object sender)
  30.         {
  31.             if (!_doc.IsDisposed)
  32.             {
  33.                 if (!m_Starting)
  34.                 {
  35.                     m_Starting = true;
  36.                     if (_doc.Editor.IsQuiescent)
  37.                     {
  38.                         try
  39.                         {
  40.                             _acUtilityType.InvokeMember
  41.                             (
  42.                                 "prompt",
  43.                                 BindingFlags.InvokeMethod,
  44.                                 null,
  45.                                 _acUtility,
  46.                                 new object[] { DateTime.Now.ToString() + "\r\n" }
  47.                             );
  48.                         }
  49.                         catch
  50.                         { }
  51.                     }
  52.                     m_Starting = false;
  53.                 }
  54.             }
  55.         }
  56.     }
  57. }
发表于 2010-2-5 10:56:00 | 显示全部楼层
  1.         [CommandMethod("tt")]
  2.         public static void Test()
  3.         {
  4.             Document doc = Application.DocumentManager.MdiActiveDocument;
  5.             Work w = new Work(doc);
  6.         }
复制代码
GMT+8, 2025-4-30 20:54 , Processed in 0.190646 second(s), 23 queries , Gzip On.
