查看: 2447|回复: 2
[基础] [求助]高手帮忙调试一下双线围墙程序,代码与样图见附件
发表于 2010-2-4 16:11:00 | 显示全部楼层 |阅读模式
本人刚学lisp;高手帮忙调试一下双线围墙程序,代码与样图见附件;程序可以绘制0.5米宽的双线,但是无法绘制0.5米的短线;高手帮忙调试一下,谢谢!!可不可以在设置个“wq”图层?谢谢了!!!
发表于 2010-2-4 17:37:00 | 显示全部楼层
(defun c:wq (/ pt pt2 i j n Le          ;剩余长度
             Long                       ;每段长度
             Ang                        ;每段角度
             Ang_W                      ;分割线角度
             pt_W pt_Ws pt_O pt_N pt_WE os)
  (setvar "cmdecho" 0)
  (setq pt (getpoint "\n输入起点:"))
  (setq pt_N pt)
  (setq pt_O pt)
  (setq Le 0)
  (command "_.pline" pt_O)
  (while (setq pt_N (getpoint pt_N "\n输入下一点:"))
    (command pt_N)
    (setq Long (+ Le (distance pt_N pt_O)))
    (setq Ang (angle pt_O pt_N))
    (setq Ang_W (- Ang (/ pi 2)))
    (setq n (fix (/ Long 10)))
    (setq pt_W (polar pt_O Ang (- 10 Le)))
    (setq pt_WE (polar pt_W Ang_W 0.5))
    (setq pt_Ws (append pt_Ws (list (list pt_W pt_WE))))
    (setq Le (- Long (* n 10)))
    (setq j 1)
    (while (< j n)
      (setq pt_W (polar pt_W Ang 10))
      ;; (command "_.pline" pt_W pt_WE "")
      (setq j (1+ j))
    (setq pt_O pt_N)
  (command "")
  (setq os (getvar "osmode"))
  (setvar "osmode" 0)
  (setq ent (entlast))
  (command "_.offset" 0.5 ent pt_WE "")
  (mapcar \
          '(lambda (lst) (command "_.pline" (car lst) (cadr lst) ""))
          pt_Ws
  (mapcar
    (function
      (lambda (lst)
    pt_Ws
  (setvar "osmode" os)
设置个“wq”图层?/ 需更多资料 / or 单纯的Layer命令?
 楼主| 发表于 2010-2-6 07:53:00 | 显示全部楼层
谢谢Andyhon!可以的。
GMT+8, 2025-2-22 19:28 , Processed in 0.194032 second(s), 27 queries , Gzip On.
