查看: 1697|回复: 4
[基础] [求助]lisp语言怎样把已绘制的实体放到指定的图层上?
发表于 2010-2-6 09:56:00 | 显示全部楼层 |阅读模式
请教高手:
谢谢赐教!!
发表于 2010-2-6 10:26:00 | 显示全部楼层
Many ways
(command "chprop" ss "" "LA" myLayer "")
 楼主| 发表于 2010-2-6 10:41:00 | 显示全部楼层
好像不行吗?高手帮忙调试一下图层处理的程序
;;选择实体放入当前层的图从
(DEFUN C:CX ()
  (setq m:err *error* *error* *merr*)
  (setvar "cmdecho" 0)
  (setq la (getvar "clayer"))
  (princ "Please select Object change to current layer: \n")
  (setq ss (ssget))
  (if (= ss nil)
    (princ "0 Object change to current layer.")
      (setq Num (sslength ss))
      (command ".chprop" ss "" "la" JMD "")
      (princ Num)
      (princ " Object change to current layer.")
  (setvar "cmdecho" 1)
  (setq *error* m:err m:err nil)
发表于 2010-2-6 11:01:00 | 显示全部楼层
      (command ".chprop" ss "" "la" la "")
 楼主| 发表于 2010-2-6 11:50:00 | 显示全部楼层
可以的,谢谢Andyhon!!!!
GMT+8, 2025-2-22 19:04 , Processed in 0.153013 second(s), 26 queries , Gzip On.
