查看: 2126|回复: 4
【求助】谁有尺寸伸缩CAD插件啊?
发表于 2010-2-23 10:28:00 | 显示全部楼层 |阅读模式
理正里的尺寸伸缩还有尺寸合并、断开就很好用,但是没有理正建筑就不行了
谁有尺寸伸缩插件啊?
附件里是理正建筑尺寸伸缩、合并、断开的动画!
发表于 2010-4-28 00:00:00 | 显示全部楼层
关注中! 我也想要
发表于 2019-2-28 20:27:59 | 显示全部楼层
(defun zm (et x /) (cdr (assoc x (entget et))))(defun pzm (nwzm y obj /)(entmod(subst(cons y nwzm)(assoc y (entget obj))(entget obj))))
(defun objnm (ent)(vla-get-objectname (vlax-ename->vla-object ent)))
(defun maxlst (pts / js i x tt jl ds)(setq        js 0 i  0) (repeat (length pts)(setq tt (nth i pts))(mapcar '(lambda (x)(if (> (setq ds (distance tt x)) js)(setq js ds jl (list x tt))))pts)(setq i (1+ i)))jl)
;;;|标注断开
(defun c:dk (/ ENT ENT1 GETPT JPT PT1 PT2 XL)(vl-load-com)(vl-cmdf "undo" "be")
(if (setq ent (car (entsel "\n选择要断开的标注<退出>:")))(progn(redraw ent 3)(setq getpt (getpoint "\n点取断开点:"))(redraw ent 4)(vl-cmdf ".copy" ent "" '(0 0) "@")(setq ent1 (entlast)) (setq pt1 (zm ent 13)pt2(zm ent 14))
(if (= (objnm ent) "AcDbAlignedDimension")(vl-cmdf ".xline" pt1 pt2 "")(vl-cmdf ".xline" "a" (angtos (zm ent 50) 0 4) pt1 ""))(setq xl(entlast))(pzm(setq jpt (vlax-curve-getClosestPointTo xl getpt))13 ent)(pzm jpt 14 ent1)(vl-cmdf ".erase" xl "")))(vl-cmdf "undo" "e")(princ))
;;;|标注合并
(defun c:dm (/ ANG1 ANG2 ENT ENT1 MAXPT PT1 PT2 PT3 PT4 PT5 PT6 PT7 XL)(vl-load-com)(vl-cmdf "undo" "be")
(if (setq ent (car(entsel "\n选择要合并对标注<退出>:")))(progn(redraw ent 3)(setq ent1 (car(entsel "\n选择另一个标注对象<退出>:")))(redraw ent 4)(setq pt1 (zm ent 13)pt2(zm ent 14) pt3  (zm ent1 13)pt4(zm ent1 14)            )
(if (= (objnm ent) "AcDbAlignedDimension")(setq ang1 (angle pt1 pt2)) (setq ang1 (zm ent 50)))
(if (= (objnm ent1) "AcDbAlignedDimension")(setq ang2 (angle pt3 pt4))(setq ang2 (zm ent1 50)))
(if (or(or(equal ang2 ang1 0.00001)(equal (+ pi ang2) ang1 0.00001))(equal (- ang2 pi) ang1 0.00001))(progn(vl-cmdf ".xline" "a" (angtos ang1 0 4) pt1 "")
(setq xl (entlast))(setq  pt5 (vlax-curve-getClosestPointTo xl pt2) pt6 (vlax-curve-getClosestPointTo xl pt3) pt7 (vlax-curve-getClosestPointTo xl pt4))(setq maxpt (maxlst (list pt1 pt5 pt6 pt7)))
(pzm (car maxpt) 13 ent)(pzm (cadr maxpt) 14 ent)(vl-cmdf ".erase" xl ent1 "")))))(vl-cmdf "undo" "e")(princ))
发表于 2020-7-10 07:29:42 | 显示全部楼层
1291500406 发表于 2019-2-28 20:27
(defun zm (et x /) (cdr (assoc x (entget et))))(defun pzm (nwzm y obj /)(entmod(subst(cons y nwzm)(a ...
断开合并尺寸标注不对了,实际长度变了
发表于 2020-7-10 07:51:39 | 显示全部楼层
可以用的,可以用的
GMT+8, 2025-5-18 00:54 , Processed in 0.186700 second(s), 26 queries , Gzip On.
