查看: 2090|回复: 4
[讨论] 请问如何实现这样加载?
发表于 2010-4-7 11:39:00 | 显示全部楼层 |阅读模式
请问如何实现这样加载?我实现想加载后先运行AA命令,才能运行BB命令,如果没有运行AA命令,则BB命令不能加载运行.如何才能做到?(这几个程序写在一个LISP文件KK.LSP内)
(defun c:aa()
       (load"C:/kk/kk.lsp")
(defun c:bb (/ a mumer tysm tysm tyl sjl tcl zqm chklay)
   (command "layer" "on" "*" "")
   (prompt "\n单显图层程序,请点取要打开的图层:")
   (setq a (ssget))
   (if (not a)
     (command "layer" "on" "*" "" "")
       (command "layer" "off" "*" "y" "")
       (setq mumer 0)
       (setq tysm (sslength a))
       (repeat tysm
  (setq ty1 (ssname a mumer))
  (setq sj1 (entget ty1))
  (setq tc1 (cdr (assoc 8 sj1)))
  (command "layer" "on" tc1 "")
  (command "layer" "on" (strcat (cdr (assoc 8 sj1)) "*") "")
  (setq mumer (1+ mumer))
发表于 2010-4-7 16:52:00 | 显示全部楼层
(defun c:aa ()
(setq flag t)
(if flag
(defun c:bb ()
程序加载后,只有运行aa后才能运行bb
 楼主| 发表于 2010-4-7 21:08:00 | 显示全部楼层
谢谢!我试试
 楼主| 发表于 2010-4-7 22:14:00 | 显示全部楼层
Gu_xl发表于2010-4-7 16:52:00(defun c:aa ()(setq flag t)(if flag(defun c:bb () ...)))程序加载后,只有运行aa后才能运行bb
我试了一下,确实不错,但是如果我的程序还有cc等与bb同级别命令程序加入,就会出现不认CC等命令,不知哪错了,如何改动?
(defun c:aa()
(setq flag t)
(if flag
   (setq a (ssget))
   (if (not a)
       (setq mumer 0)
       (repeat tysm
(defun c:nd ()
   (setvar "CMDECHO" 0)
   (setq sc (getdist "\nselect a point to point 从一点到另一点确定字体高度 :"))
   (setq bn (getint "\nInput begin number 输入起始序号:"))
   (setq sc1 (* sc 0.53))
   (while (setq p1 (getpoint "\nInsert Point :"))
    (command "text" "j" "m" p1 sc1 "" bn)
    (setq s1 (entlast))
    (setq txtn (itoa bn))
    (setq bn (1+ bn))
    (while (and (setq ss (ssget "X" (list '(0 . "TEXT") (cons 1 txtn))))
           (= (sslength ss) 2))
     (setq ss (ssdel s1 ss)
           s1 (ssname ss 0)
           ent (entget s1)
           txtn (itoa (1+ (atoi txtn)))
           ent (subst (cons 1 txtn) (assoc 1 ent) ent))
     (entmod ent)
   (setvar "CMDECHO" 1)
发表于 2010-4-7 23:40:00 | 显示全部楼层
if的结束括号位置错了
GMT+8, 2025-2-22 02:28 , Processed in 0.206448 second(s), 26 queries , Gzip On.
