查看: 2439|回复: 3
[求助]查看当前模型空间是否存在指定名称的块,必须是当前空间
发表于 2010-4-13 13:46:00 | 显示全部楼层 |阅读模式
查看当前模型空间是否存在指定名称(如“01”)的块,必须是当前空间。并记录块的基点坐标。怎么实现啊?请高手解答下
发表于 2010-4-13 18:43:00 | 显示全部楼层
  1.         [CommandMethod("tt")]
  2.         public static void Test()
  3.         {
  4.             Database db = HostApplicationServices.WorkingDatabase;
  5.             Document doc = Application.DocumentManager.GetDocument(db);
  6.             Editor ed = doc.Editor;
  7.             PromptResult resName = ed.GetString("\n请输入块名:");
  8.             if (resName.Status != PromptStatus.OK)
  9.                 return;
  10.             using (Transaction tr = db.TransactionManager.StartTransaction())
  11.             {
  12.                 BlockTableRecord btr = db.CurrentSpaceId.GetObject(OpenMode.ForRead) as BlockTableRecord;
  13.                 Layout layout = btr.LayoutId.GetObject(OpenMode.ForRead) as Layout;
  14.                 SelectionFilter filter =
  15.                     new SelectionFilter
  16.                     (
  17.                         new TypedValue[]
  18.                         {
  19.                             new TypedValue(0, "Insert"),
  20.                             new TypedValue(2, resName.StringResult),
  21.                             new TypedValue(410, layout.LayoutName),
  22.                         }
  23.                     );
  24.                 var resSel = ed.SelectAll(filter);
  25.                 if (resSel.Status != PromptStatus.OK)
  26.                     return;
  27.                 int i = 0;
  28.                 foreach (ObjectId id in resSel.Value.GetObjectIds())
  29.                 {
  30.                     BlockReference blkref = id.GetObject(OpenMode.ForRead) as BlockReference;
  31.                     ed.WriteMessage("\n找到第{0}个,基点:{1}", ++i, blkref.Position);
  32.                 }
  33.             }
  34.         }
发表于 2010-4-15 18:23:00 | 显示全部楼层
发表于 2010-4-17 19:07:00 | 显示全部楼层
收到
GMT+8, 2025-11-24 20:58 , Processed in 0.187065 second(s), 24 queries , Gzip On.
