(defun DD (ss) (command "DIMDIAMETER" ss PAUSE) (command "dim1" "new" "%%C<>{}{}" (ENTLAST) "") ) (defun DR (ss) (command "dimradius" ss PAUSE) (command "dim1" "new" "%%C<>{}{}" (ENTLAST) "") ) (defun c:DAA (/ e1) ;圆或圆弧标注 (setvar "cmdecho" 0) (setvar "pickbox" 25) (if (not (tblsearch "layer" "7标注层")) (command "-layer" "n" "7标注层" "c" "4""7标注层"""));endif (command "layer" "s" "7标注层" "") (command"osnap""end,mid,int,NOD,INS,cen,per,TAN,NEA,QUI,APP,EXT,PAR") (setq e1 (entget (car (setq s1 (entsel "选择圆或圆弧:"))))) (if (= (cdr (assoc 0 e1)) "ARC") (DR s1)) (if (= (cdr (assoc 0 e1)) "CIRCLE") (DD s1)) (princ) )
