查看: 2046|回复: 2
[求助]DataGridView数据导出到Excel的问题
发表于 2010-4-24 14:35:00 | 显示全部楼层 |阅读模式
哪位知道用流的方法把DataGridView数据导出到Excel时,如何写入指定的sheet中呢
        public static void DataGridViewToExcel(DataGridView dgv)
            SaveFileDialog dlg = new SaveFileDialog();
            dlg.Filter = "Execl files (*.xls)|*.xls";
            dlg.CheckFileExists = false;
            dlg.CheckPathExists = false;
            dlg.FilterIndex = 0;
            dlg.RestoreDirectory = true;
            dlg.CreatePrompt = true;
            dlg.Title = "保存为Excel文件";
            if (dlg.ShowDialog() == DialogResult.OK)
                Stream myStream;
                myStream = dlg.OpenFile();
                StreamWriter sw = new StreamWriter(myStream, System.Text.Encoding.GetEncoding(-0));
                string columnTitle = "";
                try
                    //写入列标题
                    for (int i = 0; i < dgv.ColumnCount; i++)
                        if (i > 0)
                            columnTitle += "\t";
                        columnTitle += dgv.Columns.HeaderText;
                    sw.WriteLine(columnTitle);
                    //写入列内容
                    for (int j = 0; j < dgv.Rows.Count; j++)
                        string columnValue = "";
                        for (int k = 0; k < dgv.Columns.Count; k++)
                            if (k > 0)
                                columnValue += "\t";
                            if (dgv.Rows[j].Cells[k].Value == null)
                                columnValue += "";
                            else
                                columnValue += dgv.Rows[j].Cells[k].Value.ToString().Trim();
                        sw.WriteLine(columnValue);
                    sw.Close();
                    myStream.Close();
                catch (Exception e)
                    MessageBox.Show(e.ToString());
                finally
                    sw.Close();
                    myStream.Close();
发表于 2010-4-24 18:55:00 | 显示全部楼层
Google:Xml Excel
 楼主| 发表于 2010-4-25 22:48:00 | 显示全部楼层
版主是说用流的方法不好吗?
GMT+8, 2025-5-2 08:58 , Processed in 0.174375 second(s), 23 queries , Gzip On.
