- 积分
- 15351
- 明经币
- 个
- 注册时间
- 2002-2-4
- 在线时间
- 小时
- 威望
- 金钱
- 个
- 贡献
- 激情
发表于 2003-7-1 12:44:00
显示全部楼层
;; COPYBLOCK.LSP Copyright ?999 Tony Tanzillo
;; AutoCAD 2000 Visual LISP / ObjectDBX Example
;; http://www.caddzone.com
;; tony.tanzillo@caddzone.com
;; This example demonstrates how to use ObjectDBX in
;; Visual LISP to directly add blocks defined in any
;; drawing file, to the current drawing.
;; (CopyBlock <FileName> <BlockName>)
;; This function copies the definition of the
;; block whose name is <BlockName> (a string),
;; from the .DWG file whose name is <FileName>
;; (a string), into the current drawing's block
;; table.
;; CopyBlock returns the new copy of the block
;; object in the current drawing's block table.
;; Note that this example performs none of the
;; error checking that is required, and does not
;; attempt to determine what actually happened
;; within the deep clone operation.
(vl-load-com)
(setq *acad* (vlax-get-acad-object))
(defun CopyBlock (DwgName BlkName / blocks dbxDoc)
(setq blocks
(vla-get-blocks
(vla-get-ActiveDocument *acad*)
(setq dbxDoc
(vla-GetInterfaceObject
*acad*
"ObjectDBX.AxDbDocument"
(vla-open dbxDoc DwgName)
(vla-CopyObjects
dbxDoc
(vlax-safearray-fill
(vlax-make-safearray
vlax-vbObject
'(0 . 0)
(list
(vla-item
(vla-get-blocks dbxDoc)
BlkName
blocks
(vlax-release-object dbxDoc)
(vla-item blocks BlkName)
(princ "\n(CopyBlock <DrawingFileName> <BlockName>)")
;;;;;;;;;;;;;;;;; CopyBlock.lsp ;;;;;;;;;;;;;;;;;;;; |
