查看: 1861|回复: 5
[基础] [求助]how to add toolbar icon in vlx file
发表于 2010-5-26 17:15:00 | 显示全部楼层 |阅读模式
dear sir,
发表于 2010-5-26 20:57:00 | 显示全部楼层
Please show an example image.
 楼主| 发表于 2010-5-27 16:55:00 | 显示全部楼层
  1. The following is a quoteZZXXQQStatements in 2010-5-26 20:57:00:
  2. Please show an example image.
复制代码
Dear sir
find attched
发表于 2010-5-31 11:30:00 | 显示全部楼层
if you use ACAD 2004, Please see the file acad.mnu.
for example:
***TOOLBARS
**TB_TOOLS
ID_TOOLS       [_Toolbar("TOOLS", _Floating, _Show, 1, 1, 1)]
ID_CLRSCR     [_Button("Clean the dased line", "rapid16.bmp", "rapid24.bmp")]^C^C^P(LOAD"CLRSCR") CLRSCR ^P
ID_SUMLEN      [_Button("Sum line", "GETLEN16.bmp", "GETLEN24.bmp")]^C^C^P(LOAD"SUMLEN") SUMLEN ^P
发表于 2010-6-1 14:01:00 | 显示全部楼层
vlx中不能含icon,如果要使用icon类似的东西,可以使用1直接画个icon,2打包icon到一个dll中调用
 楼主| 发表于 2010-6-3 13:45:00 | 显示全部楼层
Dear Sir
Thx For Reply
GMT+8, 2025-2-22 02:20 , Processed in 0.188613 second(s), 27 queries , Gzip On.
