- 积分
- 490
- 明经币
- 个
- 注册时间
- 2008-11-25
- 在线时间
- 小时
- 威望
- 金钱
- 个
- 贡献
- 激情
第一次执行命令,圆可以动态显示,第二次执行命令的时候,圆就不能动态显示了,这段代码有什么问题呢,请大家指点迷津。 -
- Imports Autodesk.AutoCAD.ApplicationServices
- Imports Autodesk.AutoCAD.Colors
- Imports Autodesk.AutoCAD.DatabaseServices
- Imports Autodesk.AutoCAD.EditorInput
- Imports Autodesk.AutoCAD.Geometry
- Imports Autodesk.AutoCAD.Runtime
- Imports Autodesk.AutoCAD.GraphicsSystem
- Imports Autodesk.AutoCAD.GraphicsInterface
- Imports Autodesk.AutoCAD.Windows
- Imports Autodesk.AutoCAD.Publishing
- Imports Autodesk.AutoCAD.PlottingServices
- Imports Autodesk.AutoCAD.ComponentModel
- Imports Autodesk.AutoCAD.LayerManager
- Public Class Class1
- Private MousePoint As Point3d = New Point3d(0, 0, 0) '保存当前鼠标位置
- Shared Cr As Circle
- <CommandMethod("mp")> Public Sub test()
- Dim Db As Database = HostApplicationServices.WorkingDatabase
- Dim ed As Editor = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument.Editor
- Dim Doc As Document = Application.DocumentManager.MdiActiveDocument
- Using LckDoc As DocumentLock = Doc.LockDocument
- Using Trans As Transaction = Db.TransactionManager.StartTransaction()
- Try
- Dim Bt As BlockTable = Trans.GetObject(Db.BlockTableId, OpenMode.ForRead)
- Dim Btr As BlockTableRecord = Trans.GetObject(Bt.Item(BlockTableRecord.ModelSpace), OpenMode.ForWrite)
- Cr = New Circle
- Cr.SetDatabaseDefaults()
- Cr.Radius = 10
- Cr.Center = New Point3d(0, 0, 0)
- Btr.AppendEntity(Cr)
- Trans.AddNewlyCreatedDBObject(Cr, True)
- ed.WriteMessage("new后圆id:" + Cr.ObjectId.ToString)
- Dim pro As PromptPointOptions = New PromptPointOptions("按左键退出...")
- AddHandler ed.PointFilter, AddressOf GetMousePoint
- Dim res As PromptPointResult = ed.GetPoint(pro)
- Dim Po1 As Point3d = res.Value
- RemoveHandler ed.PointFilter, AddressOf GetMousePoint
- Cr.ColorIndex = 1
- Trans.Commit()
- Catch ex As System.Exception
- MsgBox("Error : " + ex.Message)
- Finally
- End Try
- End Using
- End Using
- End Sub
- ''动态获取鼠标位置
- Private Sub GetMousePoint(ByVal sender As Object, ByVal e As PointFilterEventArgs)
- MousePoint = e.Context.ComputedPoint
- Dim Ed As Editor = Application.DocumentManager.MdiActiveDocument.Editor
- Try
- Dim Pt1 As Point3d = New Point3d(0, 0, 0)
- Cr.Radius = New Line(MousePoint, Pt1).Length / 2
- Cr.Center = MousePoint
- Doc.Editor.Regen()
- Ed.WriteMessage("圆id:" + Cr.ObjectId.ToString)
- Trans.Commit()
- Finally
- End Try
- End Using
- End Using
- End Sub
- End Class
