查看: 4429|回复: 3
VB如何显示/隐藏CAD的标题、菜单、命令行
发表于 2010-5-31 15:50:00 | 显示全部楼层 |阅读模式
VB如何显示/隐藏CAD的标题、菜单、工具栏、命令行、状态栏,前三样已经实现。
Private Sub AutoCADAll_Click(Index As Integer) 'CAD纳入到VB框中
    On Error Resume Next
    Set AcadApp = GetObject(, "AutoCAD.Application")   '启动AutoCad
    If Err Then
        Err.Clear
        Set AcadApp = CreateObject("AutoCAD.Application")
        If Err Then Exit Sub
    End If
    On Error GoTo 0
    lHwnd = GetParent(GetParent(AcadApp.ActiveDocument.hwnd))
    If lHwnd = 0 Then Exit Sub
    AcadApp.Visible = False
    AcadApp.WindowState = 2
    lState = AcadApp.WindowState
    GetWindowRect lHwnd, rS
    SetParent lHwnd, Frame.hwnd
    Me.ScaleMode = vbPixels
    L = GetWindowLong(lHwnd, GWL_STYLE)    '隐藏标题
    L = L And Not (WS_CAPTION)
    L = SetWindowLong(lHwnd, GWL_STYLE, L) '隐藏标题
    Call HIdeMenus_Click '隐藏菜单
    Call HideTool_Click  '隐藏CAD工具栏
    Call Form_Resize
    AcadApp.Visible = True                 '使AutoCad可见
    Set AcadDoc = AcadApp.ActiveDocument   '设acaddoc为当前图形文件
    Set Mospace = AcadDoc.ModelSpace       '设mospace为当前图形文件的模型空间
    Set MyLayer = AcadDoc.Layers
End Sub
Private Sub HideTool_Click()  '隐藏/显示CAD工具栏
    Dim Menugroup As Object
    Dim Toolbar As Object
    Dim i As Integer
    Static CadTools() As Boolean
    i = 0
    If Hidetool.Checked = False Then
        For Each Menugroup In AcadApp.MenuGroups
            ReDim CadTools(1 To Menugroup.Toolbars.Count)
            For Each Toolbar In Menugroup.Toolbars
                i = i + 1
                CadTools(i) = Toolbar.Visible '添加工具栏状态
                Toolbar.Visible = False
            Next Toolbar
        Next Menugroup
        Hidetool.Checked = True
    Else
                i = i + 1
                Toolbar.Visible = CadTools(i)
            Next Toolbar
        Next Menugroup
    End If
    'ForceForegroundWindow AcadApp.hwnd ' 将焦点切换到AutoCAD
End Sub
Private Sub HIdeMenus_Click() '隐藏/显示CAD菜单
    If hMenu <> 0 Then Exit Sub
    If HIdeMenus.Checked = False Then
        cMenu = GetMenu(lHwnd)
        SetMenu lHwnd, 0
        HIdeMenus.Checked = True
    Else
        SetMenu lHwnd, cMenu
    End If
End Sub
发表于 2012-7-26 02:40:25 | 显示全部楼层
本人调试了一个晚上也没有成功,水平太浅了,请不吝赐教给原实例好吗?    jsxygshh@163.com
十分感谢
发表于 2012-7-27 07:33:43 | 显示全部楼层
请pmq给个实例,谢谢
发表于 2012-7-29 19:07:53 | 显示全部楼层
请pmq给个实例,给看看
GMT+8, 2025-5-25 04:47 , Processed in 0.151932 second(s), 24 queries , Gzip On.
