查看: 1544|回复: 1
[求助]VBA如何计算曲线的长度
发表于 2010-6-5 18:37:00 | 显示全部楼层 |阅读模式
VBA如何计算曲线的长度!样条曲线没有长度返回的值,怎么办????
发表于 2010-6-8 09:25:00 | 显示全部楼层
第一步:在VBAIDE里先定义 GetCurveLen宏
Public Sub GetCurveLen()
    '利用VLisp计算曲线长度
    Dim LispPath As String
    LispPath = "c:\Getlen.LSP" 'Lisp文件的路径
    Dim tempS As String, tempR As Double
    tempS = ThisDrawing.GetVariable("users5")
    tempR = ThisDrawing.GetVariable("userr5")
    Dim obj As AcadEntity, pt As Variant
    ThisDrawing.Utility.GetEntity obj, pt, "选择对象:"
    ThisDrawing.SetVariable "users5", obj.Handle  '将对象的句柄放在系统变量里
    ThisDrawing.SendCommand "(load " & Chr(34) & Replace(LispPath, "\", "/") & Chr(34) & ")" & vbCr
    MsgBox "曲线长度为:" & CStr(ThisDrawing.GetVariable("userr5")) '到userr5里取值
    ThisDrawing.SetVariable "users5", tempS '还原系统变量
    ThisDrawing.SetVariable "userR5", tempR '还原系统变量
End Sub
第二步:复制下面代码存为*.lsp文件,注意文件名、路径要与上面的lisppath变量相一致
       (defun GetLen( / obj len)
  ;;功能:计算曲线长度
  (vl-load-com)
  (setq obj (vlax-ename->vla-object (handent (getvar "users5"))));;把对对象的句柄放在users5
  (setq len (vlax-curve-getDistAtParam obj (vlax-curve-getendParam obj)))
  (setvar "userr5" len);;把对对象的长度放在userr5
(GetLen)
然后运行 GetCurveLen宏
GMT+8, 2025-5-26 05:43 , Processed in 0.162709 second(s), 23 queries , Gzip On.
