查看: 2234|回复: 2
[求助]DCL中多行文本框如何实现
发表于 2010-6-7 15:39:00 | 显示全部楼层 |阅读模式
AutoCAD DCL中,EDIT_BOXED是否支持类似Windows界面中的多行文本编辑框?
现在我只能用list代替edit_box显示多行内容,但是编辑时没有能输入多行文字的控制。
发表于 2010-6-8 00:48:00 | 显示全部楼层
autolisp没有
你可以试试doslib函数库里提供的函数
或者opendcl
发表于 2010-6-8 09:31:00 | 显示全部楼层
(acet-ui-txted [text [caption [note]]])
Display a multi-line text editing dialog.
Arguments
text If provided, a text string to be displayed as the initial contents. Lines can be separated with "\r\n" sequences.
caption If provided, text to be used as the dialog caption.
note If provided, an additional text string to be displayed above the text editing control.
Return Values
A string containing the text contents if the user presses the OK button, or nil if the user presses the Cancel button.
Library: acetutil.arx
GMT+8, 2025-9-23 04:05 , Processed in 0.144876 second(s), 25 queries , Gzip On.
