查看: 1727|回复: 2
[求助]谁能帮我看看这个程序有什么不对呢
发表于 2010-6-13 18:31:00 | 显示全部楼层 |阅读模式
(defun C:bzbgpd ()
  (initget 1)
  (setq pt1 (getpoint "\n起点:"))
  (initget 1)
  (setq pt2 (getpoint "\n终点:"))
  (setq pt3 (polar pt2 (/ pi 2) 15)  ;;;获取pt3
 pt6 (polar pt2 (/ pi 2)  9)  ;;;获取pt3
        pt4 (polar pt3 (/ pi 1) 13)  ;;;获取pt3
 pt5 (polar pt3 0 13)   ;;;获取pt3
 pt7 (polar pt6 (/ pi 1) 13)  ;;;获取pt3
 pt8 (polar pt6 0 13)   ;;;获取pt3
  (command "line" pt1 pt2 ""
           "line" pt1 pt2 ""
    "line" pt2 pt3 ""
    "line" pt4 pt5 ""
    "line" pt6 pt7 ""
    "line" pt6 pt8 ""
  (setq bg -230.123;设置数值
 zpd -3.1
 zjl 1000.123
 ypd 3.2
 yjl 2000.123
  (setq bg (rtos bg 2 3);保留小数位数
 zpd (rtos zpd 2 1);保留小数位数
 zjl (rtos zjl 2 3);保留小数位数
 ypd (rtos ypd 2 1);保留小数位数
 yjl (rtos yjl 2 3);保留小数位数
  (command "text" "J" "BC" pt3 3 0 bg ;标高
           "text" "J" "BL" pt7 3 0 zpd;左坡度
    "text" "J" "TL" pt7 3 0 zjl;左距离
    "text" "J" "BR" pt8 3 0 ypd;右坡度
    "text" "J" "TR" pt8 3 0 yjl;右距离
);End bzdhd
程序有时候行,距离一大什么的就偏了
发表于 2010-6-13 19:53:00 | 显示全部楼层
增加: (setvar "osmode" 0)
  1. (defun C:tt ()
  2.   (if (and (setq pt1 (getpoint "\n起点:"))
  3.     (setq pt2 (getpoint pt1 "\n终点:"))
  4.       )
  5.     (progn
  6.       (setvar "osmode" 0)
  7.       (setq pt3 (polar pt2 (/ pi 2) 15)
  8.      pt6 (polar pt2 (/ pi 2) 9)
  9.      pt4 (polar pt3 pi 13)
  10.      pt5 (polar pt3 0 13)
  11.      pt7 (polar pt6 pi 13)
  12.      pt8 (polar pt6 0 13)
  13.      bg -230.123
  14.      zpd -3.1
  15.      zjl 1000.123
  16.      ypd 3.2
  17.      yjl 2000.123
  18.      bg (rtos bg 2 3)
  19.      zpd (rtos zpd 2 1)
  20.      zjl (rtos zjl 2 3)
  21.      ypd (rtos ypd 2 1)
  22.      yjl (rtos yjl 2 3)
  23.       )
  24.       (command "line" pt1 pt2 pt3 "" "line" pt4 pt5 "" "line" pt6 pt7 "" "line" pt6 pt8 "")
  25.       (command "text" "J" "BC" pt3 3 0 bg "text" "J" "BL" pt7 3 0 zpd "text" "J" "TL" pt7 3 0 zjl "text" "J" "BR" pt8 3 0
  26.         ypd "text" "J" "TR" pt8 3 0 yjl)
  27.     )
  28.   )
  29.   (princ)
  30. )
 楼主| 发表于 2010-6-14 13:37:00 | 显示全部楼层
太感谢了,楼上的,
GMT+8, 2025-9-23 04:12 , Processed in 0.168865 second(s), 26 queries , Gzip On.
