查看: 1727|回复: 2
求教陈老师:我的对话框为什么读不出数据?
发表于 2003-7-3 20:43:00 | 显示全部楼层 |阅读模式
陈老师:
  我设计了一个计算三心拱巷道断面积的小程序,lsp原程序运行没有问题,与对话框整合后,对话框可被激活,但从中读不出数据,现将两个程序附后,烦请陈老师给诊断一下。
   area1:dialog{
         label="巷道断面计算";
         :row{
             :boxed_column{
                          :edit_box{label="巷道宽度 b";
                                    key="edit_b";
                                    edit_width=8;
                          :edit_box{label="墙高 h3";
                                    key="edit_h3";
                                    edit_width=8;
              :boxed_column{
                          :popup_list{label="支护厚度 tt";
                                    key="edit_tt";
                                    edit_width=8;
                                    list="0\n50\n100\n150\n200\n250\n300\n350\n400";
                          :popup_list{label="地脚厚度 t1";
                                    key="edit_t1";
                                    edit_width=8;
                                    list="0\n150\n200\n250\n300\n350\n400";
                           spacer_1;
                           ok_cancel;
            (setvar "cmdecho" 0)
(setq i (getvar "dimscale"))
(setq h (* 3 i))
(setvar "gridmode" 0 )
(setq dcl_id (load_dialog "e:/applications/dcl/area1.dcl"))
(new_dialog "area1" dcl_id)
(setq b (atof (get_tile "edit_b")))
(setq h3 (atof (get_tile "edit_h3")))
(setq tt (atof (get_tile "edit_tt")))
(setq t1 (atof (get_tile "edit_t1")))
(start_dialog)
(setq s1 (/ (* b (+ h3 (* b 0.263))) 10e+05))
(setq sg (/ (* tt (+ (* b 1.330)(* tt 1.57))) 10e+05))
(setq st (/ (* 2 tt h3) 10e+05))
(if (> t1 0)
    (setq t2 (+ t1 100))
    (setq sd (/ (* t1 t2) 10e+05))
    (setq s2 (+ s1 sg st  sd))
  (setq s2 (+ s1 sg st ))
(setq wx (- s2 s1))
(setq s1 (StrCat "s1=" (rtos s1 2 3)))
(setq s2 (StrCat "s2=" (rtos s2 2 3)))
(setq wx (StrCat "wx=" (rtos wx 2 3)))
(princ s1 )
(princ s2 )
(princ wx )
(setq p (getpoint "\nENTER  The writed Point of an text"))
(command "layer" "set" "text" "")
(command "text" p (* 4 i) 0  s1  )
"(command "text" p91 (* 4 i) 0  s2  )"
发表于 2003-7-4 08:46:00 | 显示全部楼层
您对于DCL控件的动作设置还不明白。例如:
应当是:(Action_Tile "edit_b" "(SetQ b $Value)")
而不是:(setq b (atof (get_tile "edit_b")))
详细规则和有关范例参见《Visual LISP程序设计——技巧与范例》第4章
发表于 2003-7-4 09:04:00 | 显示全部楼层
对应部分这样改试试:
(action_tile "accept" (strcat
"(setq b (atof (get_tile \"edit_b\")))"
"(setq h3 (atof (get_tile \"edit_h3\")))"
"(setq tt (atof (get_tile \"edit_tt\")))"
"(setq t1 (atof (get_tile \"edit_t1\")))"
(start_dialog)
(unload_dialog dcl_id);注:须加入此句
GMT+8, 2025-5-16 01:54 , Processed in 0.189973 second(s), 25 queries , Gzip On.
