查看: 1814|回复: 0
[求助]视口选择集的问题
发表于 2010-6-25 12:00:00 | 显示全部楼层 |阅读模式
想获得文档中每一个视口的比例,但按vla-get-Viewports 获得的集合,无论图中有几个视口,视口个数总是等于0,请大家看看下面几句,哪句有问题,注意不准用ssget.
(defun OS:set_vp_scale (/ ss_viewport i en obj_viewport  vp_scale)
  (setvar "CMDECHO" 0)
  (setq ss_viewport nil vp_scale 100000 i 0)
  (vl-load-com)
  (setq *Acad (vlax-get-acad-object)
        *ADoc (vla-get-activedocument *Acad)
 (setq ss_viewport (vla-get-Viewports *ADoc))
   (vlax-for obj ss_viewport
      (setq vp_scale_lin (vla-get-CustomScale obj))
      (if (< vp_scale_lin vp_scale)(setq vp_scale vp_scale_lin))
     (vla-put-StandardScale  obj acVpCustomScale )
     (vla-put-CustomScale obj vp_scale)
  (setq ss_viewport nil)
GMT+8, 2025-9-23 04:37 , Processed in 0.167996 second(s), 25 queries , Gzip On.
