查看: 2000|回复: 2
[基础] 标注 问题 按给定参数自动标注
发表于 2010-6-28 15:52:00 | 显示全部楼层 |阅读模式
(defun di5 ()                                            ;向上连续标注 可以运行  (参考网上的程序写个简单的)
(setq pt (getpoint "\n please point:"))
(setq diml 0 i 0)
(setq dy (cadr pt))
(setq dx (car pt))
 (while (/= diml nil)
 ;(setq diml (getreal "\n please dim"))
         (setq dx1 (- dx 150))
         (setq dx2 (+ dx 400))
         (setq dy1 (+ dy diml))
         (setq pt1 (list dx1 dy))
         (setq pt2 (list dx2 dy))
         (setq pt3 (list dx1 dy1))
         (setq pt4 (list dx2 dy1))
         (setq pt5 (list dx dy1))
  (if ( = i 0) ( command "line" pt1 pt2 "") )
  (command "line" pt3 pt4 "")
  (command "line" pt pt5 "")
         (setq dy (+ dy  diml ))  ;关键之处,向上移动
         (setq i ( + i 1))
问题是:   想让上面的程序按四个给定变量运行一次
(defun c:b2()
(di5( 100 ))
(di5( 111 ))
(di5( 222 ))
(di5( 123 ))
(defun di5 ( diml)
   .......程序di5
如何写成??????????????
发表于 2010-6-28 16:39:00 | 显示全部楼层
同一帖放太多地方了,即使問題點不同,看帖的人也累,版主是熱心人,交給版主處理吧
 楼主| 发表于 2010-6-29 18:05:00 | 显示全部楼层
自己已解决
GMT+8, 2025-9-23 05:00 , Processed in 0.139533 second(s), 25 queries , Gzip On.
