查看: 1741|回复: 7
[基础] 请帮忙看看代码问题
发表于 2010-7-2 15:10:00 | 显示全部楼层 |阅读模式
defun c:pbox (/ pa pb pc pd kd gd mp1 mp2 mp3 mp4)
  (steq pa (getpoint "请输入左下角点:"))
  (steq kd (getreal "宽度:"))
  (steq gd (getreal "高度:"))
;;;以下各点又pa\kd\gd三个参数求出
  (steq pb (polar pa 0 kd))
  (steq pc (polar pb (/ pi 2) gd))
  (steq pd (polar pc pi kd))
;;;调用命令画矩形外框
  (command "pline" pa pb pc pd "c")
;;;计算各中点mp1,mps,mp3,mp4
  (setq mp1 (polar pa 0 (/ kd 2)))
  (setq mp2 (polar pb (/ pi 2) (/ gd 2)))
  (setq mp3 (polar pd 0 (/ kd 2)))
  (setq mp4 (polar pa (/ pi 2) (/ gd 2)))
;;;调用命令画矩形中线
  (command "line" mp1 mp3 " ")
  (command "line" mp2 mp4 " ")
运行后提示输入左下角点,然后就出现   :错误: no function definition: STEQ
刚学lisp请问有什么错误啊,书上说代码可以运行哦。CAD2006
发表于 2010-7-2 15:20:00 | 显示全部楼层
steq 应为 setq
 楼主| 发表于 2010-7-2 15:35:00 | 显示全部楼层
呵呵,粗心大意。丢人了,谢谢。
 楼主| 发表于 2010-7-2 15:38:00 | 显示全部楼层
改了,还是同样问题
发表于 2010-7-2 16:47:00 | 显示全部楼层
defun前面少了个括号,(defun, pi最好改成3.1415926
 楼主| 发表于 2010-7-8 11:17:00 | 显示全部楼层
谢谢,看来还是不仔细啊
发表于 2010-7-8 11:23:00 | 显示全部楼层
这两行最后的 "" 中间不要空格
  1. (defun c:pbox (/ pa pb pc pd kd gd mp1 mp2 mp3 mp4)
  2.   (setq  pa (getpoint "请输入左下角点:"))
  3.   (setq  kd (getreal "宽度:"))
  4.   (setq gd (getreal "高度:"))
  5. ;;;以下各点又pa\kd\gd三个参数求出
  6.   (setq pb (polar pa 0 kd))
  7.   (setq pc (polar pb (/ pi 2) gd))
  8.   (setq pd (polar pc pi kd))
  9. ;;;调用命令画矩形外框
  10.   (command "pline" pa pb pc pd "c")
  11. ;;;计算各中点mp1,mps,mp3,mp4
  12.   (setq mp1 (polar pa 0 (/ kd 2)))
  13.   (setq mp2 (polar pb (/ pi 2) (/ gd 2)))
  14.   (setq mp3 (polar pd 0 (/ kd 2)))
  15.   (setq mp4 (polar pa (/ pi 2) (/ gd 2)))
  16. ;;;调用命令画矩形中线
  17.   (command "line" mp1 mp3 "")
  18.   (command "line" mp2 mp4 "")
  19.   (princ)
  20. )
发表于 2010-7-8 12:15:00 | 显示全部楼层
路过 也是才学的  学习下
GMT+8, 2025-2-23 01:35 , Processed in 0.163839 second(s), 25 queries , Gzip On.
