查看: 1648|回复: 0
[基础] [求助]autolisp needed layer (on, off, freeze, lock, isolate, thaw)
发表于 2010-7-7 17:48:00 | 显示全部楼层 |阅读模式
Dear all
I WANT ADVANCE LAYER ON OF UTILITY
I’m using
(defun cTT () (command "layer" "th" "*" ""))
(defun cFF () (command "layer" "f" "*" ""))
(defun con () (command "layer" "on" "*" ""))
(defun coF () (command "layer" "off" "*" "" ""))
(defun cof ()
  (setq ss (entsel "\n Select Entity Layer to Off :"))
  (setq el (entget (car ss)))
  (setq la (cdr (assoc 8 el)))
  (command "layer" "off" la "")
  (PRINC)
GMT+8, 2025-9-23 04:57 , Processed in 0.154365 second(s), 26 queries , Gzip On.
