查看: 1427|回复: 2
[讨论] [求助]自己尝试着编了个读取面积的程序,但有问题,请大家帮帮忙!
发表于 2010-7-8 17:40:00 | 显示全部楼层 |阅读模式
我想实现 对多个面积的读取,并把结果存放到记事本里,但程序运行到area命令时,我读完
一个面积,但不知怎么让它跳出去,继续进行下一步,请好心人帮帮我!谢谢!
;GETAREA
(defun C:GETAREA()
(setq dg (getreal "请输入所需断面数:"))
(setq zg 3.5) ;字体高度
(setq a (getint "编号:"))
(setq f (open "d:\面积.txt" "a"))
(setq a (- a 1))
 while (< 1 dg)
     (setq a (1+ a))
     (setq P2 (getpoint "图号位置:"))
     (command "text")
     (command p2)
     (command zg)
     (command 0)
     (command a)
 (command "AREA")
 程序运行到这里就不知道怎么出去了,
比如我读完一个面积了,但我怎么停止呢?我如果按回车的话,就后面的也不运行了。一直停留在area这个命令里了。
 (setq a1(getvar "AREA"))
 (princ "面积 " f)
 (princ a f)
 (princ "= " f)
 (princ a1  f)
 (princ "\n" f)
  (close f)
  (prin1)
 楼主| 发表于 2010-7-8 17:40:00 | 显示全部楼层
自己先顶一下!
发表于 2010-7-8 21:20:00 | 显示全部楼层
  1. (defun C:GETAREA ()
  2. (setq dg (getreal "请输入所需断面数:"))
  3. (setq zg 3.5) ;字体高度
  4. (setq a (getint "编号:"))
  5. (setq f (open "d:\面积.txt" "a"))
  6. (setq a (- a 1))
  7. (while (< 1 dg)
  8.   (setq a (1+ a))
  9.   (setq P2 (getpoint "图号位置:"))
  10.   (command "text" p2 zg 0 a)
  11.   (command "AREA" "E" PAUSE)
  12.   (setq a1(getvar "AREA"))
  13.   (princ "面积 " f)
  14.   (princ a f)
  15.   (princ "= " f)
  16.   (princ a1 f)
  17.   (princ "\n" f)
  18.   (setq dg (1- dg))
  19. )
  20. (close f)
  21. (prin1)
  22. )
GMT+8, 2025-2-23 02:00 , Processed in 0.246023 second(s), 25 queries , Gzip On.
