查看: 1535|回复: 0
[求助]用acad2009 toolbar命令报错
发表于 2010-7-10 00:23:00 | 显示全部楼层 |阅读模式
我用acad2009打开公司的工具栏报错,具体错误信息如下。在网上搜索了相关错误信息,似乎都没人解答?有没有人碰到过类似问题?该如何解决?
非常感谢
See the end of this message for details on invoking
just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text **************
System.NullReferenceException: Object reference not set to an instance of an object.
   at Autodesk.AutoCAD.Customization.Document.OpenFileForXferTab(String filename, Boolean left)
   at Autodesk.AutoCAD.Customization.Document.OpenFileForXferTab(Boolean left)
   at Autodesk.AutoCAD.Customization.TransferTreeView.OnOpen()
   at Autodesk.AutoCAD.Customization.TransferTreeView.ToolBar_ButtonClick(Object sender, ToolBarButtonClickEventArgs e)
   at System.Windows.Forms.ToolBar.OnButtonClick(ToolBarButtonClickEventArgs e)
   at System.Windows.Forms.ToolBar.WmReflectCommand(Message& m)
   at System.Windows.Forms.ToolBar.WndProc(Message& m)
   at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m)
   at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
   at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
************** Loaded Assemblies **************
mscorlib
    Assembly Version: 2.0.0.0
    Win32 Version: 2.0.50727.3603 (GDR.050727-3600)
    CodeBase: file:///c:/WINDOWS/Microsoft.NET/Framework/v2.0.50727/mscorlib.dll
acdbmgd
    Assembly Version: 17.2.0.0
    Win32 Version: 17.2.608.0
    CodeBase: file:///C:/Program%20Files/Autodesk/ACADM%202009/AcdbMgd.DLL
System
    Win32 Version: 2.0.50727.3053 (netfxsp.050727-3000)
    CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll
AdWindowsWrapper
    Win32 Version: 17.2.56.0
    CodeBase: file:///C:/Program%20Files/Autodesk/ACADM%202009/AdWindowsWrapper.DLL
msvcm80
    Assembly Version: 8.0.50727.3053
    Win32 Version: 8.00.50727.3053
    CodeBase: file:///C:/WINDOWS/WinSxS/x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.3053_x-ww_b80fa8ca/msvcm80.dll
System.Drawing
    CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Drawing/2.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
AdWindows
    Assembly Version: 1.0.0.0
    Win32 Version: 1.0.608.0
    CodeBase: file:///C:/Program%20Files/Autodesk/ACADM%202009/AdWindows.DLL
WindowsBase
    Assembly Version: 3.0.0.0
    Win32 Version: 3.0.6920.1427 built by: SP
    CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/WindowsBase/3.0.0.0__31bf3856ad364e35/WindowsBase.dll
    CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Windows.Forms/2.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
System.Xml
    Win32 Version: 2.0.50727.3082 (QFE.050727-3000)
    CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Xml/2.0.0.0__b77a5c561934e089/System.Xml.dll
PresentationFramework
    Win32 Version: 3.0.6920.1500 built by: QFE
    CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/PresentationFramework/3.0.0.0__31bf3856ad364e35/PresentationFramework.dll
PresentationCore
    CodeBase: file:///C:/WINDOWS/assembly/GAC_32/PresentationCore/3.0.0.0__31bf3856ad364e35/PresentationCore.dll
acmgd
    CodeBase: file:///C:/Program%20Files/Autodesk/ACADM%202009/acmgd.DLL
AcMgdReverse
    CodeBase: file:///C:/Program%20Files/Autodesk/ACADM%202009/AcMgdReverse.DLL
AcMr
    CodeBase: file:///C:/Program%20Files/Autodesk/ACADM%202009/AcMr.DLL
acmgdinternal
    CodeBase: file:///C:/Program%20Files/Autodesk/ACADM%202009/acmgdinternal.DLL
System.Runtime.Serialization
    Win32 Version: 3.0.4506.2152 (SP.030729-0100)
    CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Runtime.Serialization/3.0.0.0__b77a5c561934e089/System.Runtime.Serialization.dll
AcWindows
    CodeBase: file:///C:/Program%20Files/Autodesk/ACADM%202009/AcWindows.DLL
VaAc_Verticals
    Assembly Version: 0.0.0.0
    Win32 Version: 13.0.47.0
    CodeBase: file:///C:/Program%20Files/Autodesk/ACADM%202009/VaAc_Verticals.arx
AcXrefUtil
    CodeBase: file:///C:/Program%20Files/Autodesk/ACADM%202009/AcXrefUtil.DLL
vaac_util
    CodeBase: file:///C:/Program%20Files/Autodesk/ACADM%202009/vaac_util.DLL
VaAc_service
    CodeBase: file:///C:/Program%20Files/Autodesk/ACADM%202009/VaAc_service.arx
Connectivity.Common
    Assembly Version: 13.0.47.0
    CodeBase: file:///C:/Program%20Files/Autodesk/ACADM%202009/Connectivity.Common.DLL
Connectivity.Explorer.Framework
    CodeBase: file:///C:/Program%20Files/Autodesk/ACADM%202009/Connectivity.Explorer.Framework.DLL
Connectivity.Application.VaultBase
    CodeBase: file:///C:/Program%20Files/Autodesk/ACADM%202009/Connectivity.Application.VaultBase.DLL
Connectivity.Common.Vault
    CodeBase: file:///C:/Program%20Files/Autodesk/ACADM%202009/Connectivity.Common.Vault.DLL
Connectivity.Common.Windows
    CodeBase: file:///C:/Program%20Files/Autodesk/ACADM%202009/Connectivity.Common.Windows.DLL
System.Configuration
    CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Configuration/2.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
AcPrevInput
    CodeBase: file:///C:/Program%20Files/Autodesk/ACADM%202009/AcPrevInput.DLL
AcInfoCenterConn
    CodeBase: file:///C:/Program%20Files/Autodesk/ACADM%202009/AcInfoCenterConn.DLL
AdInfoCenter
    CodeBase: file:///C:/Program%20Files/Autodesk/ACADM%202009/AdInfoCenter.DLL
AdInfoCenter.resources
    CodeBase: file:///C:/Program%20Files/Autodesk/ACADM%202009/en-US/AdInfoCenter.resources.DLL
Accessibility
    CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/Accessibility/2.0.0.0__b03f5f7f11d50a3a/Accessibility.dll
System.Web.Services
    CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Web.Services/2.0.0.0__b03f5f7f11d50a3a/System.Web.Services.dll
Autodesk.Interop.WSCommCntr1
    CodeBase: file:///C:/Program%20Files/Autodesk/ACADM%202009/Autodesk.Interop.WSCommCntr1.DLL
AcLayer
    CodeBase: file:///C:/Program%20Files/Autodesk/ACADM%202009/AcLayer.DLL
AcLayer.resources
    CodeBase: file:///C:/Program%20Files/Autodesk/ACADM%202009/en-US/AcLayer.resources.DLL
AcRibbon
    CodeBase: file:///C:/Program%20Files/Autodesk/ACADM%202009/AcRibbon.DLL
AcRibbon.resources
    CodeBase: file:///C:/Program%20Files/Autodesk/ACADM%202009/en-US/AcRibbon.resources.DLL
AcCustomize
    CodeBase: file:///C:/Program%20Files/Autodesk/ACADM%202009/AcCustomize.DLL
AcCui
    CodeBase: file:///C:/Program%20Files/Autodesk/ACADM%202009/AcCui.DLL
AcCustomize.resources
    CodeBase: file:///C:/Program%20Files/Autodesk/ACADM%202009/en-US/AcCustomize.resources.DLL
System.Data
    CodeBase: file:///C:/WINDOWS/assembly/GAC_32/System.Data/2.0.0.0__b77a5c561934e089/System.Data.dll
AcMNUParser
    CodeBase: file:///C:/Program%20Files/Autodesk/ACADM%202009/AcMNUParser.DLL
************** JIT Debugging **************
To enable just-in-time (JIT) debugging, the .config file for this
application or computer (machine.config) must have the
jitDebugging value set in the system.windows.forms section.
The application must also be compiled with debugging
enabled.
For example:
<configuration>
    <system.windows.forms jitDebugging="true" />
</configuration>
When JIT debugging is enabled, any unhandled exception
will be sent to the JIT debugger registered on the computer
rather than be handled by this dialog box.
GMT+8, 2025-7-28 04:06 , Processed in 0.182114 second(s), 25 queries , Gzip On.
