查看: 2630|回复: 3
求助:只差一步就功的程序,请高手帮忙调试
发表于 2010-7-10 17:51:00 | 显示全部楼层 |阅读模式
这段程序运行到画缓和曲线时老是提示参数错误,请高手帮忙调试一下,不胜感激:
;子程序——从编辑框取值
(defun getile()                             ;从编辑框取值均为字符串,除"数据文件名"外需化为实数
  (setq PNJd (atof (get_tile "PNjd")))                        ;get_tile从关键字为代表对话框取值
  (setq Xb (atof (get_tile "Xb")) Yb (atof (get_tile "Yb")))
  (setq Xj (atof (get_tile "Xj")) Yj (atof (get_tile "Yj")))
  (setq Xf (atof (get_tile "Xf")) Yf (atof (get_tile "Yf")))
  (setq R (atof (get_tile "R")) Ls (atof (get_tile "Ls")))
  (setq LN (atof (get_tile "LN")) CN (atof (get_tile "CN")))
  (setq D (atof (get_tile "D")) S2 (atof (get_tile "S2")))
  (setq DataFile (get_tile "DataFile"))
;主程序——缓和曲线的计算、绘图与数据输出
(defun c:ecurve1 (/ PNJd Xb Yb Xj Yj Xf Yf R Ls LN LC D S2 DataFile id)
  ;从对话框读入计算所需起始数据:
  (setq id (load_dialog "Ecurve.dcl"))                          ;加载DCL程序于内存,并获标识码id
  (if (< id 0) (exit))                                                   ;如果加载不成功,则退出
  (if (not (new_dialog "Ecurve" id)) (exit))
  (setq PNjd 0 Xb 0 Yb 0 Xj 0 Yj 0 Xf 0 Yf 0 R 0 Ls 0 LN 0 LC 0 D 0 S2 0 DataFile".txt")
        ;程序中的变量赋初值
  (action_tile "accept" "(getile) (done_dialog 1)")
                                 ;当"确定"(accept)按钮按下,控件的指定动作为getile及done_dialog
  (start_dialog)                                ;显示对话框,经数据输入,按"确定"按钮,送入主程序
  (unload_dialog id)                                     ;对话框任务完成,将DCL文件从内存中下载
  ;初步计算:
  (setq S3 (/ S2 3))                                                 ;注记点位名离点位的坐标差
  (setq N (fix (+ 1 (/ Ls LN))))                                             ;N 为缓和曲线分段数
  (setq F (open "DataFile" "w"))                                                ;打开数据文件写入
  (setq BD (list Xb Yb) JD (list Xj Yj) FD (list Xf Yf))                       ;形成二维点位表
  (setq BD1 (list (+ Xb S3)(+ Yb S3)) FD1 (list (+ Xf S3)(+ Yf S3)))
  (setq JD1 (list (+ Xj S3)(+ Yj S3)))
  (setq JD2 (list (- Xj S2)(+ Yj S3)))
  ;画道路中线交点及前后转点:
  (command "style" "standard" "宋体" "" "" "" "n" "n")                        ;字体
  (command "pdmode" 32 "pdsize" 0.6)                                  ;指定画点的模式和大小
  (command "point" JD)(command "text" JD1 S2 0 "JD")                         ;画路线交点
  (command "point" BD)(command "text" BD1 S2 0 "ZD(b)")                        ;前视转点
  (command "point" FD)(command "text" FD1 S2 0 "ZD(f)")                      ;画后视转点
  ;求交点至前后视转点及曲中点方位角(用求值函数-angle)和计算路线偏角:
  (setq Ab (angle JD BD) bA (angle BD JD))
  (setq Af (angle JD FD) fA (angle FD JD))
  (setq Am (/ (+ Ab Af) 2))                                                ;计算分角线的方位角
  (if (or (and (< (- Ab Af) PI)(> (- Ab Af) 0))(< (- Ab Af)(* PI -1)))
       (setq LR 1)(setq LR 2))                       ;判断路线方向的左、右偏,LR=1左偏,LR=2右偏
  (if (and (= LR 1)(> Af Ab))(setq Am (+ Am PI)))
  (if (and (= LR 2)(< Af Ab))(setq Am (+ Am PI)))
  (if (and (= LR 1)(> (- Af bA) 0))(setq A (- Af bA)))                             ;计算左偏角
  (if (and (= LR 1)(> (- bA Af) PI))(setq A (+ (- Af bA)(* PI 2))))
  (if (and (= LR 2)(> (- bA Af) 0))(setq A (- bA Af)))                             ;计算右偏角
  (if (and (= LR 2)(> (- Af bA) PI))(setq A (+ (- bA Af)(* PI 2))))
  ;计算缓和曲线辅助参数:
  (setq M (- (/ Ls 2)(/ (* Ls Ls Ls)(* 240 R R))))                                 ;计算m,p,β0
  (setq P (/ (* Ls Ls)(* 24 R)) B0 (/ Ls (* 2 R)))
  ;计算缓和曲线和圆曲线元素:
  (setq Lc (* R (- A (* 2 B0))) L (+ Lc (* 2 Ls)) L2 (/ L 2))                           ;计算Lc
  (setq A2 (/ A 2) TA2 (/ (sin A2)(cos A2)))                           ;计算tanα/2,因LISP无tan
  (setq TT (+ M (* (+ R P) TA2)))                                         ;计算切线长T及外矢距E
  (setq EE (- (/ (+ R P)(cos A2)) R))
  ;计算曲线主点坐标:
  (setq ZH (polar JD Ab TT))                         ;用极坐标求值函数-polar,计算直缓点大地坐标
  (setq QZ (polar JD Am EE))                                                ;计算曲中点大地坐标
  (setq HZ (polar JD AF TT))                                                ;计算缓直点大地坐标
                                                       ;计算缓圆点和圆缓点法线方位角及大地坐标:
  (setq Ye (- (/ (* Ls Ls)(* 6 R))(/ (expt Ls 4)(* 336 R R R))) Xe (- Ls (/ (expt Ls 3)(* 40 R R))))       ;Ye有错、已改
  (if (= LR 1)(setq A01 (- Ab (/ PI 2)) A02 (+ Af (/ PI 2)))
    (setq A01 (+ Ab (/ PI 2)) A02 (- Af (/ PI 2))))                           ;ZH,HZ点法线方位角
  (setq HY0 (polar ZH bA Xe))(setq HY (polar HY0 A01 Ye))                           ;HY大地坐标
  (setq YH0 (polar HZ fA Xe))(setq YH (polar YH0 A02 Ye))                           ;YH大地坐标
  (setq ZH1 (polar ZH (/ PI 6) S3) ZH2 (polar ZH PI S2))                        ;算注记起点坐标
  (setq QZ1 (polar QZ (/ PI 6) S3) QZ2 (polar QZ PI S2))
  (setq HZ1 (polar HZ (/ PI 6) S3) HZ2 (polar HZ PI S2))
  (setq HY1 (polar HY (/ PI 6) S3) HY2 (polar HY PI S2))
  (setq YH1 (polar YH (/ PI 6) S3) YH2 (polar YH PI S2))
  ;画曲线主点:
  (command "layer" "m" "曲线主点" "c" "red" "" "")                          ;建道路曲线主点图层
  (command "point" ZH)(command "text" ZH1 S2 0 "ZH")                          ;画曲线起点
  (command "point" QZ)(command "text" QZ1 S2 0 "QZ")                              ;画中点
  (command "point" HZ)(command "text" HZ1 S2 0 "HZ")                              ;画终点
  (command "point" HY)(command "text" HY1 S2 0 "HY")                            ;画缓圆点
  (command "point" YH)(command "text" YH1 S2 0 "YH")                            ;画圆缓点
  ;计算曲线主点桩号:
  (setq PNzh (- PNjd TT) PNqz (+ PNzh L2) PNhz (+ PNzh L))
  (setq PNhy (+ PNzh Ls) PNyh (- PNhz Ls))
                                                   ;以下用实数转字符函数-rtos注记桩号,取2位小数
  (setq Pzh (rtos PNzh 2 2) Pqz (rtos PNqz 2 2) Phz (rtos PNhz 2 2))
  (setq Pjd (rtos PNjd 2 2) Phy (rtos PNhy 2 2) Pyh (rtos PNyh 2 2))
  (setq rtoa (/ 180 PI))                        ;用弧角转换函数-rtoa,将方位角弧度化为角度(度)
  (setq Az (* rtoa (+ Ab (/ PI 2))))
  (setq Ah (* rtoa (- Af (/ PI 2))))
  (setq Aq (* rtoa Am))
  ;注记曲线主点桩号:
  (command "layer" "m" "桩号" "c" "yellow" "" "")                             ;建立桩号注记图层
  (command "text" ZH2 S2 Az Pzh)                                ;注记交点起点中点终点缓圆点桩号
  (command "text" HZ2 S2 Ah Phz)(command "text" QZ2 S2 Aq Pqz)
  (command "text" JD2 S2 (+ Aq 180) Pjd)
  (command "text" HY2 S2 Az Phy)(command "text" YH2 S2 Ah Pyh)
  (command "zoom" "e")
  ;曲线元素及主点桩号计算的文件输出:
  (princ "  缓和曲线文件名:    " F)(princ DataFile F)(princ "\n" F)
  (princ "\n" F)(princ "  道路转点坐标(y,x):    " F)(princ "\n" F)
  (princ "    ZD(b)" F)(princ BD F)(princ "    JD" F)(princ JD F)
  (princ "    ZD(F)" F)(princ FD F)(princ "\n" F)
  (princ "\n" F)(princ "  曲线设计数据:    " F)(princ "  R = " F)
  (princ R F)(princ "  Ls = " F)(princ Ls F)
  (princ "\n" F)(princ "\n" F)
  (princ "  曲线计算数据:    " F)(princ "  a = " F)
  (princ (angtos A 1 4) F)
  (princ "  m = " F)(princ M F)(princ "  p = " F)(princ P F)
  (princ "  T = " F)(princ TT F)(princ "\n" F)
  (princ "  E = " F)(princ EE F)(princ "  Lc = " F)
  (princ Lc F)(princ "  L = " F)(princ L F)
  (princ "  β0 = " F)(princ (angtos B0 1 4) F)(princ "\n" F)
  (princ "\n" F)
  (princ "  曲线主点桩号及坐标(y,x):    " F)(princ "\n" F)
  (princ "    ZH:  " F)(princ Pzh F)(princ "    " F)(princ ZH F)
  (princ "\n" F)
  (princ "    HY:  " F)(princ Phy F)(princ "    " F)(princ HY F)
  (princ "\n" F)
  (princ "    QZ:  " F)(princ Pqz F)(princ "    " F)(princ QZ F)
  (princ "\n" F)
  (princ "    YH:  " F)(princ Pyh F)(princ "    " F)(princ YH F)
  (princ "\n" F)
  (princ "    HZ:  " F)(princ Phz F)(princ "    " F)(princ HZ F)
  ;画道路中线的切线和圆曲线:
  (command "layer" "m" "路线切线" "c" "4" "" "")
  (command "line" BD JD FD "")
  (command "layer" "m" " 圆曲线" "c" "1" "" "")
  (command "arc" HY QZ YH "")
  ;缓和曲线(一)细部点及边线点计算坐标,输送至文件和画点位:
  (princ " 缓和曲线(一)细部点桩号及中桩和左、右边桩坐标(y,x): " F)
  (princ "\n" F)
  (setq LEi 0 BF 1 Origin ZH A0 bA)                         ;开始以直缓点为原点,切线为起始方向
  (setq PNi PNzh)                         ;桩号(PN)从直缓点开始,逐点增加,"i"代表缓和曲线上的点
  (repeat N
    (setq Xi (- LEi (/ (expt LEi 5)(* 40 (* R R)(* Ls Ls)))))
    (setq Yi (/ (expt LEi 3)(* 6 R Ls)))                                         ;计算独立坐标
    (if (or (and (= BF 1)(= LR 2))(and (= BF 2)(= LR 1)))
      (setq Yi (* Yi-1)))
    (setq Bi (/ (* LEi LEi)(* 2 R Ls)))(if (= LR 2)(setq Bi (* Bi -1)))
    (setq Ari (+ A0 Bi (/ PI 2)))                               ;计算缓和曲线点i曲率半径方位角
    ;将独立坐标转换为大地坐标
    (setq XXi (+ (nth 0 Origin)(- (* Xi (cos A0))(* Yi (sin A0)))))
    (setq YYi (+ (nth 1 Origin)(+ (* Yi (cos A0))(* Xi (sin A0)))))
    (setq I (list XXi YYi))
    (setq Li (polar I Ari D) Ri (polar I (+ Ari PI) D))                    ;计算左、右边桩点位
    (setq Eback (cons I Eback))                          ;将缓和曲线(一)的细部点放入点表-Eback
    ;画缓和曲线的中线点及边桩点:
    (command "layer" "m" "曲线细部点" "c" "green" "" "")
    (command "point" I "")(command "point" Li "")(command "point" Ri "")
    ;缓和曲线细部点坐标计算的文件输出:
    (princ "    " F)(princ PNi F)(princ "    " F)(princ I F)
    (princ "    " F)(princ Li F)(princ "    " F)(princ Ri F)
    (princ "\n" F)
    (setq LEi (+ LEi LN) PNi (+ PNi LN))                      ;点号增大,曲线点的计算长度也增大
) ; End repeat
(setq Eback (reverse Eback))                          ;用样条曲线画缓和曲线,点表中元素倒序排列
(command "layer" "m" "缓和曲线" "c" "magenta" "" "")
(command "spline" ZH)(setq i 1)                                                ;从直缓点开始画
(repeat (- N 1)                                         ;从缓和曲线点表中依次取出各点画缓和曲线
(setq Pt (nth i Eback))(command Pt)(setq i (+ i 1))
);End repeat
(command "" "" "" "")                                                      ;结束画缓和曲线(一)
;圆曲线细部点及边线点计算坐标,输送至文件和画点位:
(princ "\n" F)
(princ " 圆曲线细部点桩号及中桩和左、右边桩坐标(y,x): " F)(princ "\n" F)
(setq PNj 0)                             ;开始计算圆曲线上细部点(整桩)桩号,"j"代表圆曲线上的点
(setq PN0 (rem PNhy CN) PN1 (- CN PN0) PNj (+ PNhy PN1))                        ;用求余函数rem
                                ;求缓圆点前整桩距PN0,后整桩距PN1,在计算圆曲线上第一个整桩号PNj
(setq LCj (- PNj PNzh))                                          ;计算整桩至直缓点距离(起点距)
(while (< PNj PNyh)
  (setq Bj (+ B0 (/ (- LCj Ls) R)))                                    ;计算圆曲线点的独立坐标
  (setq Xj (+ (* R (sin Bj)) M))
  (setq Yj (+ (* R (- 1 (cos Bj))) P))
    (setq Yj (* Yj -1)))
  (setq Aj (+ B0 (/ (- LCj Ls) R)))(if (= LR 2)(setq Aj (* Aj -1)))
  (setq ARi (+ A0 Aj (/ PI 2)))                                 ;计算圆曲线点j的曲率半径方位角
  ;将独立坐标变换为大地坐标
  (setq XXj (+ (nth 0 Origin)(- (* Xj (cos A0))(* Yj (sin A0)))))
  (setq YYj (+ (nth 1 Origin)(+ (* Yj (cos A0))(* Xj (sin A0)))))
  (setq J (list XXj YYj))
  (setq Lj (polar J ARi D) Rj (polar J (+ ARi PI) D))                      ;计算左、右边桩点位
  ;画圆曲线的中线点及边桩点:
  (command "layer" "m" "曲线细部点" "")
  (command "point" J "")(command "point" Lj "")(command "point" Rj "")
  ;圆曲线细部点坐标计算的文件输出:
  (princ "    " F)(princ PNj F)(princ "    " F)(princ J F)
  (princ "    " F)(princ Lj F)(princ "    " F)(princ Rj F)
  (princ "\n" F)
  (setq LCj (+ LCj CN) PNj (+ PNj CN))                             ;起点距及桩号均增加一个桩距
); End while
  ;缓和曲线(二)细部点及边线点计算坐标,输送至文件和画点位:
  (princ "\n" F)
  (princ " 缓和曲线(二)细部点桩号及中桩和左、右边桩坐标(y,x): " F)
  (princ "\n" F)
  (setq LEi Ls BF 2 Origin Hz A0 fA)                         ;开始以缓直点为原点,切线为起始方向
  (setq PNi PNyh)                                                    ;桩号从圆缓点开始,逐点增加
  (repeat N
    (if (and (= BF 2)(= LR 1))(setq Yi (* Yi-1)))
    (setq Bi (/ (* LEi LEi)(* 2 R Ls)))(if (= LR 1)(setq Bi (* Bi -1)))
        ;将独立坐标转换为大地坐标
    (setq Ri (polar I Ari D) Li (polar I (+ Ari PI) D))                    ;计算左、右边桩点位
    (setq Efore (cons I Efore))                          ;将缓和曲线(二)的细部点放入点表-Efore
    ;画缓和曲线的中线点及边桩点:
    ;缓和曲线细部点坐标计算的文件输出:
    (princ "\n" F)
    (setq LEi (- LEi LN) PNi (+ PNi LN))                        ;点号增大,曲线点的计算长度减小
) ; End repeat
(setq Efore (reverse Efore))                          ;用样条曲线画缓和曲线,点表中元素倒序排列
(command "spline" YH)(setq i 1)                                                ;从圆缓点开始画
    (setq Pt (nth i Efore))(command Pt)(setq i (+ i 1))
);End repeat
(command "" "" "" "")                                                      ;结束画缓和曲线(二)
(setq Eback nil Efore nil)                                     ;清空点表可继续算另一条道路曲线
)        ;《ECURVE1》程序结束!
发表于 2010-7-10 21:34:00 | 显示全部楼层
因不懂算法,又无调试数据,未调试,仅从语法考虑修改了一下。
 楼主| 发表于 2010-7-12 19:52:00 | 显示全部楼层
谢谢,我试试
 楼主| 发表于 2010-7-12 20:30:00 | 显示全部楼层
已解决,多谢ZZ版主的帮忙
GMT+8, 2025-11-3 04:03 , Processed in 0.161073 second(s), 24 queries , Gzip On.
