查看: 2445|回复: 3
[求助]VBA做打印的问题
发表于 2010-7-12 07:53:00 | 显示全部楼层 |阅读模式
我做了一个打印的程序,因为自己使用做的比较简单,通过选择多段线方框或者图块来确定打印区域,来实现批量打印;本来小心操作的话用着没有问题,可是今天同事的 一个图拷过来打印的时候发现,打印区域会跑,偏移到空白的地方去了,但是把这张图的内容拷到一张新建的图里再打又能用了,不知道是什么问题,求助帮忙看下,下面的事全部的代码,有个窗体带了两个列表框,打印机和图纸的列表,谢谢!
Private Sub CmdOK_Click()
    '保证选项完整
    If cmb1.text = "" Or cmb1.text = "无" Then
        Label1.Caption = "请选择打印机!"
        Exit Sub
    End If
    If cmb2.text = "" Then
        Label1.Caption = "请选择图纸类型!"
        Exit Sub
    End If
    '确保当前布局是模型空间
    ThisDrawing.ActiveLayout = ThisDrawing.Layouts.Item("Model")
    '设置打印设备
    If Not cmb1.text = "" Or cmb1.text = "无" Then
        ThisDrawing.ActiveLayout.ConfigName = cmb1.text
    Else
    End If
    '设置打印比例为"布满图纸"
    ThisDrawing.ActiveLayout.StandardScale = acScaleToFit
    ' 设置图纸是否居中打印
    ThisDrawing.ActiveLayout.CenterPlot = True
    '设置图纸类型
    If Not cmb2.text = "" Then
         ThisDrawing.ActiveLayout.CanonicalMediaName = cmb2.text
    Else
    End If
    ThisDrawing.ActiveLayout.PaperUnits = acMillimeters
    ' 设置是否应用打印样式
    ThisDrawing.ActiveLayout.PlotWithPlotStyles = True
    ' 设置打印样式表
    ThisDrawing.ActiveLayout.StyleSheet = "Tarch7.ctb"
    '让AutoCAD在前台进行打印
    ThisDrawing.SetVariable "BACKGROUNDPLOT", 0
    '--------------------设置打印窗口----------------------------------------
    Dim i As Integer
    Dim dkxset As AcadSelectionSet
    Dim element As AcadEntity
    Dim aaa As Long
    Dim fType(0 To 3) As Integer
    Dim fData(0 To 3) As Variant
    '设置过滤
    fType(0) = -4: fData(0) = "<or"
    fType(1) = 0: fData(1) = "INSERT"
    fType(2) = 0: fData(2) = "LWPOLYLINE"
    fType(3) = -4: fData(3) = "or>"
    On Error Resume Next
    Set dkxset = ThisDrawing.SelectionSets.Add("ss1")
    Me.Hide
    dkxset.SelectOnScreen fType, fData
    If Err Then
        Err.Clear
        Set dkxset = ThisDrawing.SelectionSets.Item("ss1")
        dkxset.Clear
        dkxset.Delete
    End If
    aaa = dkxset.Count
    i = 0
    Dim minxx() As Double
    Dim minyy() As Double
    Dim maxxx() As Double
    Dim maxyy() As Double
    ReDim minxx(aaa)
    ReDim minyy(aaa)
    ReDim maxxx(aaa)
    ReDim maxyy(aaa)
    For Each element In dkxset
        element.GetBoundingBox minpoint, maxpoint
        Call ThisDrawing.Utility.TranslateCoordinates(minpoint, acWorld, acDisplayDCS, False)
        Call ThisDrawing.Utility.TranslateCoordinates(maxpoint, acWorld, acDisplayDCS, False)
        minxx(i) = minpoint(0): minyy(i) = minpoint(1)
        maxxx(i) = maxpoint(0): maxyy(i) = maxpoint(1)
        i = i + 1
   Next
   dkxset.Clear
   dkxset.Delete
   Dim minpt(0 To 1) As Double, maxpt(0 To 1) As Double
   i = 0
   Dim num As Integer
   num = 0
   For i = 0 To aaa - 1
        If Not minxx(i) = maxxx(i) Or minyy(i) = maxyy(i) Then
            num = num + 1
        End If
    Next i
    Dim pt1(0 To 2) As Double
    Dim pt2(0 To 2) As Double
        minpt(0) = minxx(i): minpt(1) = minyy(i)
        maxpt(0) = maxxx(i): maxpt(1) = maxyy(i)
        pt1(0) = minpt(0): pt1(1) = minpt(1): pt1(2) = 0
        Call ThisDrawing.ModelSpace.AddCircle(pt1, 200)
        pt2(0) = maxpt(0): pt2(1) = maxpt(1): pt2(2) = 0
        Call ThisDrawing.ModelSpace.AddCircle(pt2, 200)
        If Not minpt(0) = maxpt(0) Or minpt(1) = maxpt(1) Then
            '设置打印方向
            If (maxpt(0) - minpt(0)) < (maxpt(1) - minpt(1)) Then
                ThisDrawing.ActiveLayout.PlotRotation = ac0degrees   '纵向
            Else
                ThisDrawing.ActiveLayout.PlotRotation = ac90degrees  '横向
            End If
            '设置窗口对角点
            ThisDrawing.ActiveLayout.SetWindowToPlot minpt, maxpt
            '设置打印类型
            ThisDrawing.ActiveLayout.PlotType = acWindow
            '打印
                ThisDrawing.plot.PlotToDevice cmb1.text
            Else
                ThisDrawing.plot.PlotToDevice "Adobe PDF"
            End If
        Else
            num = num - 1
        End If
    Next i
    '恢复系统变量的值
    ThisDrawing.SetVariable "BACKGROUNDPLOT", 2
    ThisDrawing.Utility.Prompt num & "张图打印完毕!"
End Sub
发表于 2010-7-12 11:57:00 | 显示全部楼层
上面加上
' 重新生成当前图形
ThisDrawing.Regen acActiveViewport
试试
另外:
'设置打印设备
    Else
    End If
'设置图纸类型
    Else
    End If
红色部分代码补全
 楼主| 发表于 2010-7-12 14:28:00 | 显示全部楼层
还是不行啊,主要问题可能出在这个循环这里,代码中在窗口的两个角点处画了两个圆做标记,点的位置没有错,但是选的窗口却偏移了好多
            '设置打印方向
            Else
            End If
            '设置窗口对角点
            '设置打印类型
            '打印
            Else
            End If
        Else
            num = num - 1
        End If
    Next i
发表于 2013-6-1 13:44:47 | 显示全部楼层
这个先记下了。研究研究。
GMT+8, 2025-5-24 19:49 , Processed in 0.199022 second(s), 24 queries , Gzip On.
