查看: 1483|回复: 2
如何在已有的块上添加块定义
发表于 2010-7-15 10:01:00 | 显示全部楼层 |阅读模式
如题,我写的代码如下,好像没出错,但是重新打开之后没有发现块有定义
        Dim db As Database = New Database(False, True)
        db.ReadDwgFile(Path, System.IO.FileShare.ReadWrite, True, "")
        Using trans As Transaction = db.TransactionManager.StartTransaction()
            Dim bt As BlockTable = trans.GetObject(db.BlockTableId, OpenMode.ForWrite)
            If Not bt.Has(curUnitName) Then
                Return
            End If
            Dim btr As BlockTableRecord = trans.GetObject(bt(curUnitName), OpenMode.ForWrite)
            Dim attdef As New AttributeDefinition
           attdef.Tag = “SP"
           attdef.TextString = "SPText"
           btr.AppendEntity(attdef)
           trans.Commit()
        End Using
        db.Dispose()
发表于 2010-7-15 10:39:00 | 显示全部楼层
没有保存到文件:)
 楼主| 发表于 2010-7-20 11:15:00 | 显示全部楼层
nice
GMT+8, 2025-5-14 13:33 , Processed in 0.225436 second(s), 23 queries , Gzip On.
