我很久以前的写的lsp文件删除注释工具 试试呢。
清除后效果如下。。- (DEFUN C:AT (/ X Y Z XDAT SS LENG SIZ DSC EXDENT SS2 XDSS XDAT_SS BALLSS MAT_SEL BH_MAKE QUAD_BALL BALLCFG LAYSEL QUAD_ACT GET_SIZ BH_STD NORM_PNTS STATUS ) (SETVAR "blipmode" 0) (SETQ USO (GETVAR "OSMODE")) (SETVAR "blipmode" 0) (SETQ CL (GETVAR "CLAYER")) (SETQ NWL "BOM") (SETQ LAYT nil) (SETQ LAYT (TBLSEARCH "LAYER" NWL)) (IF (NOT LAYT) (COMMAND "LAYER" "NEW" NWL "") ) (SETVAR "clayer" NWL) (SETVAR "CMDECHO" 0) (DEFUN DTR (A) (* PI (/ A 180.0)) ) (DEFUN RTD (A) (/ (* A 180.0) PI) ) (DEFUN NORM_PNTS (/ ANG ARCA BALLSS Y1 BCX BCY BALLCNT ARK STA ENDA TOTANG BALLANG X2 X3 Y1 Y2 Y3 STAP ENBH BR STAPX STAPY C ROT ) (SETQ PT1 (LIST (CAR PT1) (NTH 1 PT1) 0.0)) (SETQ X1 (CAR PT1)) (SETQ Y1 (CAR (CDR PT1))) (SETQ BALLR (/ (ATOF BALLDIA) 2.0) ARWS (GETVAR "DIMASZ") ) (PROGN (SETVAR "osmode" USO) (PROGN (INITGET 1) (SETQ PT2 (GETPOINT " \nPick a point for arc elbow:")) ) (PROMPT " \n Pick a point for balloon center:") (COMMAND "ARC" PT1 PT2 PAUSE) (SETQ PT3 (GETVAR "LASTPOINT")) (SETQ ARK (ENTLAST)) (IF OVER (EXIT) ) (SETVAR "OSMODE" USO) (SETQ STA (RTD (CDR (ASSOC 50 (ENTGET ARK))))) (SETQ ENDA (RTD (CDR (ASSOC 51 (ENTGET ARK))))) (SETQ ARCA (- STA ENDA)) (SETQ PT4 (TRANS (CDR (ASSOC 10 (ENTGET ARK))) 0 1)) (SETQ BR (CDR (ASSOC 40 (ENTGET ARK)))) (SETQ PT2 (OSNAP PT2 "MID")) (ENTDEL ARK) (SETQ MA (RTD (ANGLE PT4 PT2))) (SETQ C (DISTANCE PT1 PT3)) (SETQ TOTANG (* 2 (RTD (ATAN (/ (/ C 2.0) (SQRT (- (EXPT BR 2) (EXPT (/ C 2.0) 2) ) ) ) ) ) ) ) (SETQ BALLANG (* 2 (RTD (ATAN (/ (/ BALLR 2.0) (SQRT (- (EXPT BR 2) (EXPT (/ BALLR 2.0 ) 2 ) ) ) ) ) ) ) ) (SETQ AA (* 2 (ATAN (/ (/ ARWS 2.0) (SQRT (- (EXPT BR 2) (EXPT (/ ARWS 2.0) 2) ) ) ) ) ) ) (SETQ X2 (CAR (TRANS PT3 1 0))) (SETQ X3 (CAR PT2)) (SETQ Y1 (CAR (CDR PT1))) (SETQ Y2 (CAR (CDR (TRANS PT3 1 0)))) (SETQ Y3 (CAR (CDR PT2))) (SETQ STAP (POLAR PT4 (DTR STA) BR)) (SETQ ENBH (POLAR PT4 (DTR ENDA) BR)) (SETQ STAPX (NTH 0 STAP)) (SETQ STAPY (NTH 1 STAP)) (IF (= (RTOS X1 2 4) (RTOS STAPX 2 4)) (SETQ ROT "CW" AA (* 180 (/ AA PI)) ) (SETQ ROT "CCW" AA (* -180 (/ AA PI)) ) ) (SETQ AW (* (/ (GETVAR "DIMasz") 0.18) 0.06)) (IF (AND (> (DISTANCE (INTERS PT1 PT3 PT2 PT4 nil ) PT2 ) (DISTANCE PT3 PT4) ) (< TOTANG 270) ) (SETQ TOTANG (- 360 TOTANG)) ) (SETQ MID (- (ABS TOTANG) (ABS BALLANG) (ABS AA))) (IF (= ROT "CCW") (SETQ MID (* (ABS MID) -1.0)) (SETQ MID (ABS MID)) ) (SETQ USO (GETVAR "osmode")) (SETVAR "OSMODE" 0) ) ) (SETQ XDAT nil) (IF (NOT BALLDIA) (PROGN (PROMPT "\nPlease wait, searching for last balloon inserted to pull variables........\n(to override use Balloon settings)") (IF (SETQ XDSS (SSGET "X" (LIST (QUOTE (-3 ("bhPRO_B")))))) (PROGN (SETQ START (CDR (NTH 1 (CDR (LAST (ASSOC -3 (ENTGET (SSNAME XDSS 0 ) (QUOTE ("bhpro_b") ) ) ) ) ) ) ) ) (IF BALL_OVERIDE (SETQ BALLDIA (GETCFG "APPDATA/bompro/BALLDIA") BALL_OVERIDE nil ) (SETQ BALLDIA (CDR (NTH 0 (CDR (LAST (ASSOC -3 (ENTGET (SSNAME XDSS 0) (QUOTE ("bhpro_b") ) ) ) ) ) ) ) ) ) (SETCFG "APPDATA/bompro/BALLDIA" BALLDIA) (SETCFG "APPDATA/bompro/start" START) ) (SETQ BALLDIA (GETCFG "APPDATA/bompro/BALLDIA") START (GETCFG "APPDATA/bompro/start") ) ) ) ) (REBOUND) (WHILE (NOT (= (PROGN (INITGET 129) (SETQ PT1 (GETPOINT " \n Pick a point on detail, pick point for Quad balloon or hit enter to EXIT:")) ) "" ) ) (SETQ XDAT nil) (IF (NOT (= PT1 "")) (PROGN (IF (SETQ TP (OSNAP PT1 "NEAR")) (SETQ PT1 TP) ) (SETQ QUAD nil) (NORM_PNTS) (SETVAR "ATTDIA" 0) (SETVAR "ATTDIA" 1) (COMMAND) (IF (NOT QUAD) (PROGN (COMMAND "._pline" PT1 "width" "0.0" AW "a" "a" AA "C" PT4 "width" "0.0" "0.0" "a" MID "C" PT4 "" ) ) ) ) ) (SETQ QUAD nil) ) (SETVAR "CLAYER" CL) (SETVAR "osmode" USO) (PROMPT "\nThank for using a bhPro product... ") (PRINC))
