查看: 1789|回复: 4
[基础] [讨论]取中点,哪里错误?
发表于 2010-7-21 10:24:00 | 显示全部楼层 |阅读模式
(defun c:zd()
(setq l1 (entsel "\n 选择直线:"))
(setq d (entget (car l1)))
(setq P1 (cdr (assoc 10 d)))
(SETQ P11 (POLAR P1 0 1000))
(setq P2 (cdr (assoc 11 d)))
(setq d1 (car p1))
(setq d2 (cadr p1))
(setq d3 (car p2))
(setq d4 (cadr p2))
(setq m1 (+ d2 d1))
(setq m2 (+ d4 d3))
(setq dd '(m1 m2))
(princ dd)
dd的输入错误!
发表于 2010-7-21 10:47:00 | 显示全部楼层
旨趣不明,先试这个再论
(setq dd '(m1 m2))
(setq dd (List m1 m2))
 楼主| 发表于 2010-7-21 11:01:00 | 显示全部楼层
改正了,输出的m1,怎么不是(d1+d2)的结果?
发表于 2010-7-21 11:49:00 | 显示全部楼层
若不借助Vlide,也可以這麼辦
(setq d1 (car p1))
(terpri)
(princ d1)
(setq d2 (cadr p1))
(terpri)
(princ d2)
驗證 D1 & D2
 楼主| 发表于 2010-7-21 13:22:00 | 显示全部楼层
(defun c:zd()
(setq sel1 (ssget))
(setq d1 (car p1))
(setq d2 (cadr p1))
(setq d3 (car p2))
(setq d4 (cadr p2))
(setq m1 (/ (+ d1 d3) 2))
(setq m2 (/ (+ d2 d4) 2))
(setq mm (list m1 m2))
(if(> d2 d4)
(command "rotate" sel1 "" mm "r" p2 p1 90 "")
(command "rotate" sel1 "" mm "r" p1 p2 90 "")
谢谢Andyhon 就想自己做一个90°摆正的程序
GMT+8, 2025-2-23 01:42 , Processed in 0.161185 second(s), 25 queries , Gzip On.
