查看: 1273|回复: 2
这个出错应该怎么处理?
发表于 2010-8-6 17:02:00 | 显示全部楼层 |阅读模式
    Public Function CurveLength(ByVal ID As ObjectId, ByRef Len As Double) As Boolean
        CurveLength = True
        Dim DB As Database = HostApplicationServices.WorkingDatabase
        Using Trans As Transaction = DB.TransactionManager.StartTransaction
            Try
                Dim Ent As Entity = Trans.GetObject(ID, OpenMode.ForRead)
                Dim Cur As Curve = Ent '此处如果不是线,会出错,用了TRY了,为什么不能跳到CATCH 处执行
                Len = Cur.GetDistanceAtParameter(Cur.EndParam)
            Catch ex As Exception
                CurveLength = False
                MsgBox("不正常")
            End Try
        End Using
    End Function
发表于 2010-8-6 19:15:00 | 显示全部楼层
If Ent Is Curve Then
 楼主| 发表于 2010-8-6 20:29:00 | 显示全部楼层
谢谢!我想问的是为什么此处出错,不跳到CATCH处执行呢?
GMT+8, 2025-5-11 11:08 , Processed in 0.153207 second(s), 23 queries , Gzip On.
