查看: 2275|回复: 3
指定基点插入dwg文件,如何做?
发表于 2010-8-11 16:31:00 | 显示全部楼层 |阅读模式
  这是《手册》上的代码,画两个圆并复制到另一个文件里,我想复制过去后将圆放在我指定的位置,请教大家看看,如何修改
  [CommandMethod("CopyObjectsBetweenDatabases", CommandFlags.Session)]
        public static void CopyObjectsBetweenDatabases()
            ObjectIdCollection acObjIdColl = new ObjectIdCollection();
            // Get the current document and database
            Document acDoc = Application.DocumentManager.MdiActiveDocument;
            Database acCurDb = acDoc.Database;
            // Lock the current document
            using (DocumentLock acLckDocCur = acDoc.LockDocument())
                // Start a transaction
                using (Transaction acTrans = acCurDb.TransactionManager.StartTransaction())
                    // Open the Block table record for read
                    BlockTable acBlkTbl = acTrans.GetObject(acCurDb.BlockTableId, OpenMode.ForRead) as BlockTable;
                    // Open the Block table record Model space for write
                    BlockTableRecord acBlkTblRec = acTrans.GetObject(acBlkTbl[BlockTableRecord.ModelSpace], OpenMode.ForWrite) as BlockTableRecord;
                    // Create a circle that is at (0,0,0) with a radius of 5
                    Circle acCirc1 = new Circle();
                    acCirc1.SetDatabaseDefaults();
                    acCirc1.Center = new Point3d(0, 0, 0);
                    acCirc1.Radius = 5;
                    // Add the new object to the block table record and the transaction
                    acBlkTblRec.AppendEntity(acCirc1);
                    acTrans.AddNewlyCreatedDBObject(acCirc1, true);
                    // Create a circle that is at (0,0,0) with a radius of 7
                    Circle acCirc2 = new Circle();
                    acCirc2.SetDatabaseDefaults();
                    acCirc2.Center = new Point3d(0, 0, 0);
                    acCirc2.Radius = 7;
                    acBlkTblRec.AppendEntity(acCirc2);
                    acTrans.AddNewlyCreatedDBObject(acCirc2, true);
                    // Add all the objects to copy to the new document
                    acObjIdColl.Add(acCirc1.ObjectId);
                    acObjIdColl.Add(acCirc2.ObjectId);
                    // Save the new objects to the database
                    acTrans.Commit();
                // Unlock the document
            // Change the file and path to match a drawing template on your workstation
            string sLocalRoot = Application.GetSystemVariable("LOCALROOTPREFIX") as string;
            string sTemplatePath = sLocalRoot + "Template\\acad.dwt";
            // Create a new drawing to copy the objects to
            DocumentCollection acDocMgr = Application.DocumentManager;
            Document acNewDoc = acDocMgr.Add(sTemplatePath);
            Database acDbNewDoc = acNewDoc.Database;
            // Lock the new document
            using (DocumentLock acLckDoc = acNewDoc.LockDocument())
                // Start a transaction in the new database
                using (Transaction acTrans = acDbNewDoc.TransactionManager.StartTransaction())
                    // Open the Block table for read
                    BlockTable acBlkTblNewDoc;
                    acBlkTblNewDoc = acTrans.GetObject(acDbNewDoc.BlockTableId,
                    // Open the Block table record Model space for read
                    BlockTableRecord acBlkTblRecNewDoc;
                    acBlkTblRecNewDoc = acTrans.GetObject(acBlkTblNewDoc[BlockTableRecord.ModelSpace],
                                                        OpenMode.ForRead) as BlockTableRecord;
                    // Clone the objects to the new database
                    IdMapping acIdMap = new IdMapping();
                    acCurDb.WblockCloneObjects(acObjIdColl, acBlkTblRecNewDoc.ObjectId, acIdMap,
                                               DuplicateRecordCloning.Ignore, false);
                    // Save the copied objects to the database
                    acTrans.Commit();
                foreach(ObjectId id in acObjIdColl)
                    CxwEdit.Mirror(id, new Point3d(100, 100, 0), new Point3d(100, 200, 0), false);
            // Set the new document current
            // acDocMgr.MdiActiveDocument = acNewDoc;
 楼主| 发表于 2010-8-11 16:33:00 | 显示全部楼层
对不起,以下两句是我加的,不能正确运行,
发表于 2010-8-11 16:43:00 | 显示全部楼层
你的acObjIdColl是源数据库的,
应该改变的是目标数据库
发表于 2010-10-31 18:12:00 | 显示全部楼层
看不懂,但一定要顶
GMT+8, 2025-7-2 13:31 , Processed in 0.166722 second(s), 23 queries , Gzip On.
