查看: 1927|回复: 1
[讨论] [讨论]关于闭合多义线框内扣图(请斑主、大侠们指点,多谢)
发表于 2010-8-11 21:05:00 | 显示全部楼层 |阅读模式
程序如下:
(defun c:knkc( / cmdecho_bak en en1 os pot pt ptlist ss1)
  (setq cmdecho_bak (getvar "cmdecho"))
  (setvar "cmdecho" 0)
  (setq os (getvar "osmode"))
  (if (/= os 0)
    (setvar "osmode" 0)
  (setq en(car(entsel"\n请选择闭合多义线:")))
  (setq pt (getpoint "\n请选择方向点:"))
  (command "offset" 0.3 en pt "")
  (setq en1 (entlast))
  (setq ptlist (ptlist-get en1))
  (entdel en1)
  (command "trim"
               en
               "f"
               (foreach pot ptlist (command pot) "")
  (setq ss1 (ssget "_wp" ptlist))
  (command "erase" ss1 "")
  (setvar "osmode" os)
(defun ptlist-get (en / ptlist fst)
  (setq ent (entget en))
  (foreach n ent
    (if   (= 10 (car n))
      (setq ptlist (cons (cdr n) ptlist))
  (setq fst (car ptlist))
  (setq ptlist (cons fst (reverse ptlist)))
  ptlist
程序测试后,对于复杂闭合多义线框内扣图,程序有时失效,刚接触LISP不久,不知道哪里有问题?因不知道如何求得闭合多义线框内一点,在程序里加了(setq pt (getpoint "\n请选择方向点:")),请请斑主、大侠们指点,多谢
发表于 2010-8-13 20:17:00 | 显示全部楼层
我的程序被改了
GMT+8, 2025-9-23 07:24 , Processed in 0.159447 second(s), 25 queries , Gzip On.
