查看: 3043|回复: 3
[求助]修改旋转文字角度源码
发表于 2010-8-12 09:58:00 | 显示全部楼层 |阅读模式
(defun c:test1( / ent ents ang)
  (setq ent (car (nentsel)))
  (setq ents (entget ent))
  (setq ang (getangle "\n输入角度:"))
  (setq ents (subst (cons 50 ang) (assoc 50 ents) ents))
  (entmod ents)
  (entupd ent)
怎样将上面这段源码中的点选改为框选?
发表于 2010-8-12 12:54:00 | 显示全部楼层
(defun c:test1 (/ ent ents ang)
  (princ "选择要修改的文字,可多选")
  (setq ss (ssget '((0 . "*TEXT"))))
  (setq k 0)
  (repeat (sslength ss)
      (setq ent (ssname ss k))
      (entmod ents)
      (entupd ent)
      (setq k (1+ k))
发表于 2023-1-5 11:49:39 | 显示全部楼层
2楼威武霸气,这么短的代码实现了
发表于 2023-1-6 20:55:37 | 显示全部楼层
(defun c:tt ()
  (setq ang(Uangle 1 "" "角度<输入或鼠标直接量取>" ang nil))
  (princ "选择要修改的文字: ")
  (if (setq ss (ssget '((0 . "*TEXT"))))
    (xyp-SubUpd ss 50 ang)
GMT+8, 2025-11-13 04:27 , Processed in 0.156737 second(s), 24 queries , Gzip On.
