查看: 1818|回复: 5
[讨论]求救!! 高人入内帮解答下
发表于 2010-8-21 22:54:00 | 显示全部楼层 |阅读模式
这是一位高人帮我弄得程式 但我使用不了 它会显示错误: no function definition: SORTLIST1   我也不知道如何改 希望高人可以指导下
我改了Vl-sort list1  现在成了这样了选择对象:  ; 错误: 函数错误: 6.64656
(defun c:cw ()
  (defun cwt1 ()
    (setq m 0)
    (repeat (length lisx)
      (setq ps (nth m lisx))
      (setq m (1+ m))
      (setq px (vl-prin1-to-string (car ps))
     py (vl-prin1-to-string (Cadr ps))
;;;      (setq px (vl-prin1-to-string px)
;;;     py (vl-prin1-to-string px)
      (setq str  (strcat "X坐标为:.." px)
     str1 (strcat "Y坐标为:.." py)
      (cwt #pp #hh str)
      (cwt (POLAR #pp 0.0 (* #hh 15.0)) #hh str1)
      (setq #pp (polar #pp (* pi 1.5) (+ 1.5 #hh)))
    (setq m    nil
   ps   nil
   px   nil
   py   nil
   str  nil
   str1 nil
  (defun cwt (#pt #hh txt1)
;;;    (if (tblsearch "style" "hz")
;;;      (SETVAR "TEXTSTYLE" "hz")
;;;      (progn
;;; (command "-style" "hz" "txt,xc02" "" "0.7" "" "" "")
    (setq #pt (trans #pt 1 0))
    (setq eli (list (cons 0 "TEXT")
      (cons 7 "HZ")
      (CONS 8 "TXT")
      (CONS 10 #PT)
      (CONS 40 #hh)
      (CONS 1 TXT1)
      (CONS 41 0.75)
    (ENTMAKE ELI)
  (defun ccw2 ()
    (vl-load-com)
    (SETQ #PP (GETPOINT (list 0 0) "\n 请输入文本的基准点:..."))
    (cwt #pp #hh "所选圆实体的圆心,直径列表__前生<OursCAD@21cn.com>")
    (setq #pp (polar #pp (* pi 1.5) (+ 2.5 #hh)))
    (setq n 0)
    (repeat (length lisr)
      (setq r (nth n lisr))
      (setq n (1+ n))
      (setq count 0)
      (setq lisx nil)
      (setq str (strcat "圆 C"
   (rtos n 2 0)
   " 列表, 直径为:__"
   (vl-prin1-to-string (* 2.0 r))
      (cwt #pp #hh str)
      (while (< count (sslength ss))
 (setq en (ssname ss count))
 (setq count (1+ count))
 (setq #r (cdr (assoc 40 (entget en))))
 (if (= r #r)
     (setq p (trans (cdr (assoc 10 (entget en))) 0 1))
     (setq lisx (cons p lisx))
 )    ;end of if
      )     ;end of while
      (cwt1)
    (setq n nil
   r nil
   count nil
   lisx nil
   str nil
   en nil
   #r nil
   p nil
    (setq cwt1 nil
   #pp  nil
   #hh  nil
   str  nil
  (defun ccw1 ()
    (setq count 0)
    (setq lisr nil)
    (setq #hh nil)
      (setq r (cdr (assoc 40 (entget en))))
      (setq lisr (cons r lisr))
    (setq en nil
   r nil
   count nil
    (setq lisr (vl-sort lisr '<))
    (setq lisr (sortlist1 lisr))
    (IF (NULL
   (sETQ #HH (GETDIST "\n 请输入文本的高度<缺省高度为2.5MM>:.."))
      (SETQ #HH 2.5)
    (setq n 0)
      (setq n (1+ n))
      (setq count 0)
 (setq str (strcat "C" (rtos n 2 0)))
 (if (= r #r)
;;; (if (equal r #r 0.000001)
;;;     (setq ed (entget en))
;;;     (entdel en)
;;;     (entmake ed)
     (setq pt (cdr (assoc 10 (entget en))))
;;;     (setq pt (cdr (assoc 10 ed)))
       (cons 7 "HZ")
       (CONS 8 "TXT")
       (CONS 10 PT)
       (CONS 40 #hh)
       (CONS 1 str)
       (CONS 41 0.75)
     (ENTMAKE ELI)
 )    ;end of if
      )     ;end of while
    (setq count nil
   en nil
   r nil
   n nil
   str nil
   pt nil
   eli nil
    (Ccw2)
  (setq ss nil)
;;;  (c_hz "HZ" 0.7 0 "TXT.SHX" "1.SHX")
  (setq ss (ssget (list (cons 0 "circle,arc"))))
  (if ss
    (ccw1)
    (prompt "\n 未选择到圆实体:..")
  (setq ccw1 nil
 ccw2 nil
  (setq ss  nil
 eli nil
;;;  (prompt (strcat "\n" (getcfg "appdata/tel")))
  (prompt " ___circle.lsp")
发表于 2010-8-21 23:13:00 | 显示全部楼层
楼主是不是想要个圆坐表列表呀?我传个SPRING大侠的文件给你,好用哦,命令就是文件名
发表于 2010-8-22 08:12:00 | 显示全部楼层
缺少自定义函数
SORTLIST1
发表于 2010-8-22 14:28:00 | 显示全部楼层
呵呵,本人用的怎么没有问题呀?对了,此程序只支持2004版的,楼上再试试看哦
 楼主| 发表于 2010-8-22 18:48:00 | 显示全部楼层
哦哦!! 但怎么是2004可以用2006就不行@@
发表于 2010-8-22 19:14:00 | 显示全部楼层
这个我也没有研究哦,要请教我们的版主才知道嘀
GMT+8, 2025-9-23 07:24 , Processed in 0.419359 second(s), 26 queries , Gzip On.
