查看: 6065|回复: 16
[函数] [求助]用lisp调用vb把ANSI编码的文件转换成UTF-8
发表于 2010-8-22 21:30:00 | 显示全部楼层 |阅读模式
  1. Private Sub Command1_Click()
  2. Dim FileName As String, b() As Byte, S As String
  3. Dim ADO_Stream As Object
  4. FileName = App.Path & "\1.txt" '请修改为具体文件名
  5. If Dir(FileName) = "" Then Exit Sub
  6. ReDim b(FileLen(FileName))
  7. Open FileName For Binary As #1
  8. Get #1, , b
  9. Close #1
  10. S = StrConv(b, vbUnicode)
  11. Set ADO_Stream = CreateObject("ADODB.Stream")
  12. With ADO_Stream
  13. .Type = 2
  14. .Mode = 3
  15. .Charset = "utf-8"
  16. .open
  17. .WriteText S
  18. .SaveToFile FileName, 2
  19. End With
  20. Set ADO_Stream = Nothing
  21. MsgBox "文件转换完毕!"
  22. End Sub
上面是一段vb程序源码,可把ANSI编码的文件转换成UTF-8
可怜小弟太菜,不懂vb,只懂一点lsp
哪位老师可代为修改一下,让lsp调用
对话框就不用了,给出文件地址,自动转换就可以了,不用什么提示的
先谢谢了
发表于 2019-11-3 22:44:39 | 显示全部楼层
UTF-8编码的文件转换成ANSI
(xzj-file-WriteTextFile  "c:\\ansi.txt"   (xzj-file-ReadTextFile    "c:\\ansi.txt"  "utf-8")   "gb2312")
ANSI编码的文件转换成UTF-8
(xzj-file-WriteTextFile  "c:\\ansi.txt"   (xzj-file-ReadTextFile     "c:\\ansi.txt"  "gb2312")   "utf-8")
(defun xzj-file-ReadTextFile (File charset / encode filepath filestream)
  (if
    (and
      (setq FilePath   (findfile File))
      (setq FileStream (vlax-create-object "Adodb.Stream"))
      (vlax-put-property FileStream 'Type 2) ;1二进制读取 2文本模读取
      (vlax-put-property FileStream 'mode 3) ;1-读,2-写,3-读写
      (vlax-put-property FileStream 'charset charset)        ;unicode;utf-8;Ascii;gb2312;big5;gbk
      (vlax-invoke FileStream 'Open)
      (vlax-invoke FileStream 'LoadFromFile filePath)
      (setq Encode (vlax-invoke FileStream 'readtext))
      (vlax-invoke FileStream 'close)
      (vlax-release-object FileStream)
      Encode
)(defun xzj-file-WriteTextFile (File charset str /  filestream)
;;;判断文件路径是否存在
(if (findfile (vl-filename-directory File))
     (if
            (vlax-invoke FileStream 'WriteText str)
            (vlax-invoke FileStream 'SaveToFile File 2)
            (vlax-invoke FileStream 'flush)
            (vlax-invoke FileStream 'Close)
            T
     (princ "\n文件路径不存在,无法创建文件!")
      nil
(xzj-file-WriteTextFile "c:\\ansi.txt" "utf-8" (xzj-file-ReadTextFile "c:\\ansi.txt" gb2312"))  发表于 2020-2-25 23:58
参与人数 2明经币 +3 金钱 +5 收起 理由
xyp1964 + 3 赞一个!
flowerson + 5 很给力!
回复 支持 2 反对 0
发表于 2020-2-25 02:20:04 | 显示全部楼层
xshrimp 发表于 2019-11-3 22:44
UTF-8编码的文件转换成ANSI
(xzj-file-WriteTextFile  "c:\\ansi.txt"   (xzj-file-ReadTextFile    "c:\\ ...
;我把它合并
;例如 (file-encode-trans  "c:\\ansi.txt"   "gb2312"    "utf-8")
(defun file-encode-trans (file charset1 charset2 / obj encode)
  (setq obj (vlax-create-object "ADODB.Stream"))
  (vlax-put-property obj 'type 2);1二进制读取 2文本模读取
  (vlax-put-property obj 'mode 3);1-读,2-写,3-读写
  (vlax-invoke obj 'open)
  (vlax-put-property obj "charset" charset1);;unicode;utf-8;ascii;gb2312;big5;gbk
  (vlax-invoke-method obj 'loadfromfile file)
  (setq encode (vlax-invoke obj 'readtext))
  (vlax-invoke obj 'close)
  (vlax-release-object obj)
  (vlax-put-property obj "charset" charset2);;unicode;utf-8;ascii;gb2312;big5;gbk
  (vlax-invoke obj 'writetext encode)
  (vlax-invoke-method obj 'savetofile file 2);1新建,2覆盖
  (vlax-invoke obj 'flush);将缓存中的数据强制输出
发表于 2010-8-23 14:35:00 | 显示全部楼层
检查文件的编码
;;命令: (GPS->CHECKCODE "c:\\unicode big endian.txt")
;;"unicode big endian"
;;命令: (GPS->CHECKCODE "c:\\unicode.txt")
;;"Unicode"
;;命令: (GPS->CHECKCODE "c:\\utf-8.txt")
;;"UTF-8"
;;命令: (GPS->CHECKCODE "c:\\ansi.txt")
;;"GB2312"
(gps->WriteToFile  "c:\\utf8.txt"  "Str" "utf-8")
(gps->ReadFile     "c:\\ansi.txt" "gb2312")
转化文件编码
ANSI编码的文件转换成UTF-8
(gps->gtu  "c:\\ansi.txt")
 楼主| 发表于 2010-8-23 18:30:00 | 显示全部楼层
太感谢了
发表于 2010-8-23 19:19:00 | 显示全部楼层
UTF-8编码的文件转换成ANSI
(gps->WriteToFile  "c:\\ansi.txt"   (gps->ReadFile     "c:\\ansi.txt"  "utf-8")   "gb2312")
ANSI编码的文件转换成UTF-8
(gps->WriteToFile  "c:\\ansi.txt"   (gps->ReadFile     "c:\\ansi.txt"  "gb2312")   "utf-8")
 楼主| 发表于 2010-8-23 22:50:00 | 显示全部楼层
再次感谢xshrimp,这个对我来说太重要了
发表于 2019-11-1 16:11:07 | 显示全部楼层
xshrimp 发表于 2010-8-23 19:19
UTF-8编码的文件转换成ANSI(gps->WriteToFile  "c:\\ansi.txt"   (gps->ReadFile  ...
不知可否提供源码下载?可以收点明经币都可以。
发表于 2019-11-4 01:15:12 | 显示全部楼层
非常谢谢xshrimp。xzj-file-WriteTextFile 里面的三参数顺序 File charset str 应该是File  str charset对吧?
发表于 2020-2-25 02:31:00 | 显示全部楼层
flowerson 发表于 2019-11-4 01:15
非常谢谢xshrimp。xzj-file-WriteTextFile 里面的三参数顺序 File charset str 应该是File  str charset ...
确实如此!
GMT+8, 2025-4-22 01:23 , Processed in 0.229451 second(s), 29 queries , Gzip On.
