查看: 3170|回复: 2
[求助]关于effectivename的问题
发表于 2010-9-7 13:09:00 | 显示全部楼层 |阅读模式
一个图中带属性图块,块修改命令后,(entget (car (entsel)))得到
((-1 . <图元名: 7c242640>)  (5 . "3A2348") (102 .
"{ACAD_XDICTIONARY") (360 . <图元名: 7c242648>) (102 . "}") (330 . <图元名:
7ee9cc10>) (100 . "AcDbEntity") (67 . 0) (410 . "Model") (8 . "cxb_给水立管") (100
. "AcDbBlockReference") (66 . 1)(2 . "*U1677")(10 4.42682e+006 869774.0 0.0)
(41 . -1.0) (42 . 1.0) (43 . 1.0) (50 . 0.0) (70 . 0) (71 . 0) (44 . 0.0) (45 .
0.0) (210 0.0 0.0 1.0))
而修改前为
((-1 . <图元名: 7797a2f0>) (0 . "INSERT") (330 . <图元名: 7ee9cc10>) (5 .
"3A5766") (100 . "AcDbEntity") (67 . 0) (410 . "Model") (8 . "cxb_排水") (100 .
"AcDbBlockReference") (66 . 1) (2 . "cxb_bg") (10 4.42545e+006 870722.0 0.0)
(41 . 1.0) (42 . 1.0) (43 . 1.0) (50 . 0.0) (70 . 0) (71 . 0) (44 . 0.0) (45 .
用(ssget '((0 . "INSERT")(2 . "*U1677")))找不到图块,而只能通过
(if (ssget '((0 . "insert")))
    (vlax-for n
(vla-get-activeselectionset
 (vla-get-activedocument (vlax-get-acad-object))
      (if (wcmatch (vla-get-effectivename n) "cxb_bg")
          (setq blk (ssadd (vlax-vla-object->ename n) blk))
得到选择集,用(vla-get-IsDynamicBlock n)为:VLAX_False,能否将(2 . "*U1677")变回原来的(2 . "cxb_bg")?
发表于 2010-9-7 14:35:00 | 显示全部楼层
(ssget '((0 . "INSERT")(2 . "`*U1677")))加个 ` 符号就可以选中了啊
 楼主| 发表于 2010-9-7 16:42:00 | 显示全部楼层
多谢
GMT+8, 2025-5-19 19:27 , Processed in 0.158631 second(s), 25 queries , Gzip On.
