我在网上下的多段线修测得lisp源代码,但是不知道怎么运行啊 我可以加载但是不能用啊 怎么办?
源代码:
;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;线延伸;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;; (defun c:extendline (/ ensel ename object point width points first end) (setq osmode (getvar "osmode")) (if (setq ensel (entsel "\n请选择一根线:")) (progn (setvar "cmdecho" 0) (setvar "osmode" 0) (command "undo" "g") (setq ename (car ensel)) (setq object (vlax-ename->vla-object ename)) (if (= (vla-get-entityname object) "AcDbPolyline") (if (vlax-curve-isClosed object) (alert "这根线是闭合的!") (progn (setq width (car (vla-getWidth object 0 'StartWidth, 'EndWidth))) (setvar "plinewid" width) (setq point (cadr ensel)) (setq point (list (car point) (cadr point) )) (setq points (poly_pts (vla-get-coordinates object))) (setq first (car points)) (setq end (last points)) (if (< (distance point first) (distance point end)) (drawline first t points) (drawline end nil points) ) (setvar "plinewid" 0) ) ) (princ "\n这个程序只支持LWPOLYLINE!") ) (vlax-release-object object) (command "undo" "e") (setvar "osmode" osmode) (prin1) ) ) ) (defun drawline (d_pt d_mode d_pts / draw) (setq draw t) (while draw (initget 128) (setq d_pt (getpoint d_pt "\n撤消[U]/闭合[C]/<下一点>:")) (cond ((or (= d_pt "u") (= d_pt "U")) (if (equal d_pts points) (if d_mode (setq d_pt (car d_pts)) (setq d_pt (car (reverse d_pts))) ) (progn (if d_mode (setq d_pts (cdr d_pts) d_pt (car d_pts) ) (setq d_pts (reverse (cdr (reverse d_pts))) d_pt (car (reverse d_pts)) ) ) (vla-put-coordinates object (apply 'append d_pts)) (command "pedit" ename "w" width "") ) ) ) ((= (type d_pt) 'list) (progn (setq d_pt (list (car d_pt) (cadr d_pt))) (if d_mode (setq d_pts (cons d_pt d_pts)) (setq d_pts (reverse (cons d_pt (reverse d_pts)))) ) (vla-put-coordinates object (apply 'append d_pts)) (command "pedit" ename "w" width "") ) ) ((or (= d_pt "c") (= d_pt "C")) (command "pedit" ename "c" "") (setq draw nil)) ((= d_pt nil) (setq draw nil)) (t (print "输入错误!") (if d_mode (setq d_pt (car d_pts)) (setq d_pt (car (reverse d_pts))) ) ) ) )
