查看: 1803|回复: 0
[分享]用C#实现命令“创建要素”的实现方法
发表于 2010-9-25 10:10:00 | 显示全部楼层 |阅读模式
平台:vs.net2008 AutoCAD Map3d 2010
部份实现代码:
using OSGeo.MapGuide;
using Autodesk.AutoCAD.DatabaseServices;
using Autodesk.AutoCAD.EditorInput;
using Autodesk.Gis.Map.Platform;
using Autodesk.Gis.Map.Platform.Interop;
        /// <summary>
        /// 创建要素
        /// </summary>
        public void CreateFeature()
            AcMapMap currentMap = AcMapMap.GetCurrentMap();
            MgLayerCollection layers = currentMap.GetLayers();
            MgLayerBase layer = SelectLayer(layers);
            MgClassDefinition classDef = layer.GetClassDefinition();
            MgPropertyDefinitionCollection propDefs = classDef.GetProperties();
            ObjectIdCollection objIds = CGcEditor.SelectEntities();
             int count = 0;
             Database db =
                     Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument.Database;
             TransactionManager tm = db.TransactionManager;
             using (Transaction transaction = tm.StartTransaction())
                 foreach (ObjectId objId in objIds)
                     Entity entity = (Entity)tm.GetObject(objId, OpenMode.ForWrite, false);
                     bool addSuccess = AddFeature(layer, entity);
                     if (addSuccess)
                         count++;
                         entity.Erase();
                 string msg = "Convert the entity to feature successfully.";
                 if (count > 1)
                     msg = string.Format("Converted {0} entities to features successfully!", count);
                 if (count > 0)
                     CGcEditor.ShowMessage(msg);
                 transaction.Commit();
        /// <summary>
        /// Entity -> MgGeometry
        /// </summary>
        private bool AddFeature(MgLayerBase layer, Entity entity)
            if (layer == null || entity == null)
                return false;
            MgGeometry geometry = CEntityToGeometryConverter.EntityToGeometry(entity);
            if (geometry == null)
                return false;
            string featClassName = layer.FeatureClassName;
            MgGeometricPropertyDefinition geoPropDef = propDefs.GetItem(classDef.DefaultGeometryPropertyName)
        as MgGeometricPropertyDefinition;
            int layerGeometryType = geoPropDef.GeometryTypes;
            int geoType = geometry.GetGeometryType();
            if (!GeometryTypeValidate(layerGeometryType, geoType))
                CGcEditor.ShowMessage("Geometry type of the entity is invalid to the targeting layer.");
                return false;
            MgPropertyCollection props = new MgPropertyCollection();
            props = InputPropertyValues(propDefs, geometry);
            if (props != null)
                MgInsertFeatures insertFeat = new MgInsertFeatures(featClassName, props);
                MgFeatureCommandCollection featCommands = new MgFeatureCommandCollection();
                featCommands.Add(insertFeat);
                try
                    layer.UpdateFeatures(featCommands);
                catch (System.Exception e)
                    CGcEditor.ShowMessage("Failed to add a Feature.");
                    CGcEditor.ShowMessage(e.Message);
                    return false;
                return true;
            else
                CGcEditor.ShowMessage("Operation cancelled");
                return false;
        /// <summary>
        /// Convert Entity to MgGeometry.
        /// </summary>
        public static MgGeometry EntityToGeometry(Entity entity)
            if (entity == null)
                return null;
            MgGeometry geometry = null;
            string entityType = entity.GetType().Name;
            switch (entityType)
                case "DBPoint":
                    geometry = PointGeometryConvert((DBPoint)entity);
                    break;
                case "Line":
                    geometry = LineGeometryConvert((Line)entity);
                    break;
                case "Polyline":
                    geometry = PolylineGeometryConvert((Polyline)entity);
                    break;
                case "MPolygon":
                    geometry = MPolygonGeometryConvert((MPolygon)entity);
                    break;
                default:
                    break;
            return geometry;
参与人数 1威望 +1 明经币 +1 收起 理由
雪山飞狐_lzh + 1 + 1 【好评】表扬一下
GMT+8, 2025-4-10 00:49 , Processed in 0.305118 second(s), 25 queries , Gzip On.
