查看: 1896|回复: 0
引线标注如何赋三维点的Z值?
发表于 2010-10-9 16:37:00 | 显示全部楼层 |阅读模式
请教各位:
  创建引线标注时创建了一个AcDbMText和一个AcDbLeader ,Leader如何赋三维点的Z值?
  我直接采用AutoCAD.NET开发手册的CODE,更改Z值如-10时,Leader的Z值仍为0,而且无法建立两者的关联性(提示运行错误!)。代码如下:
<CommandMethod("AddLeaderAnnotation")> _
    Public Sub AddLeaderAnnotation()
        '' Get the current database
        Dim acDoc As Document = Application.DocumentManager.MdiActiveDocument
        Dim acCurDb As Database = acDoc.Database
        '' Start a transaction
        Using acTrans As Transaction = acCurDb.TransactionManager.StartTransaction()
            '' Open the Block table for read
            Dim acBlkTbl As BlockTable
            acBlkTbl = acTrans.GetObject(acCurDb.BlockTableId, _
                                         OpenMode.ForRead)
            '' Open the Block table record Model space for write
            Dim acBlkTblRec As BlockTableRecord
            acBlkTblRec = acTrans.GetObject(acBlkTbl(BlockTableRecord.ModelSpace), _
                                           OpenMode.ForWrite)
            '' Create the MText annotation
            Dim acMText As MText = New MText()
            acMText.SetDatabaseDefaults()
            acMText.C
            acMText.Location = New Point3d(5, 5, -10)
            acMText.Width = 2
            '' Add the new object to Model space and the transaction
            acBlkTblRec.AppendEntity(acMText)
            acTrans.AddNewlyCreatedDBObject(acMText, True)
            '' Create the leader with annotation
            Dim acLdr As Leader = New Leader()
            acLdr.SetDatabaseDefaults()
            acLdr.AppendVertex(New Point3d(0, 0, -10))
            acLdr.AppendVertex(New Point3d(4, 4, -10))
            acLdr.AppendVertex(New Point3d(4, 5, -10))
            acLdr.HasArrowHead = True
            acBlkTblRec.AppendEntity(acLdr)
            acTrans.AddNewlyCreatedDBObject(acLdr, True)
            '' Attach the annotation after the leader object is added
            acLdr.Annotation = acMText.ObjectId
            acLdr.EvaluateLeader()
            '' Commit the changes and dispose of the transaction
            acTrans.Commit()
        End Using
    End Sub
GMT+8, 2025-4-10 00:44 , Processed in 0.162025 second(s), 24 queries , Gzip On.
