查看: 1661|回复: 1
[基础] [求助] apply赋值出错,类型不对
发表于 2010-10-12 09:09:00 | 显示全部楼层 |阅读模式
(defun c:l1()
(setq ci (getreal "分割数:"))
(setq r (getreal "半径:"))
(setq jiao (getangle "角度:"))
(setq p0 '(0 0 0))
(command "arc" p0 "e" (polar p0 0 (* 2 r)) "r" r)
(setq hu1(entlast))
  (command "pline" p0)
(repeat (fix ci)
  (setq n 1)
(setq dist (/ (* pi r) ci))
(setq p1 (vlax-curve-getPointAtDist hu1 (* n dist)))
(setq p1_x (car p1))
(setq disty (apply '(lambda (x a)
   (* (/ (sin a) (cos a)) x))
   '(p1_x jiao)
  (setq p11 (list p1_x disty))
    (setq n (1+ n))
  (command p11)
(command "")
 apply赋值出错了,说是number类型错误:jiao
删除中间却不会有类型不对
发表于 2010-10-12 11:09:00 | 显示全部楼层
   '(p1_x jiao)
直接改为
(setq disty    (* (/ (sin jiao) (cos jiao)) p1_x))
GMT+8, 2025-2-23 19:49 , Processed in 0.165495 second(s), 25 queries , Gzip On.
