查看: 1561|回复: 0
求助,关于“运行时错误55 文件以打开“
发表于 2010-10-13 21:18:00 | 显示全部楼层 |阅读模式
请教各位大侠,我编了一段程序,为什么运行时总显示 “运行时错误55 文件以打开”?
Option Explicit
Public Sub WriteTextFile()
'获得文件路径
Dim FileName As String, FileNumber As Integer
FileName = "D:\2.txt"
FileNumber = FreeFile()
'打开文件
Open FileName For Output As #FileNumber
'将图形中所有的点的坐标保存到文件中
 Dim point As AcadPoint
 For Each point In ThisDrawing.ModelSpace
  Dim ptcoordinates As Variant
  ptcoordinates = point.Coordinates
  Write #FileNumber, ptcoordinates(0), ptcoordinates(1), ptcoordinates(2)
 Next point
'关闭文件
Close #FileNumber
End Sub
GMT+8, 2025-10-10 04:10 , Processed in 0.115482 second(s), 24 queries , Gzip On.
