查看: 2081|回复: 5
[求助]如何利用图中对象创建图块?
发表于 2010-10-16 10:52:00 | 显示全部楼层 |阅读模式
选择图中对象,然后创建图块,用.net变成能实现吗?
发表于 2010-10-16 12:36:00 | 显示全部楼层
选择对象-》建立图块-》DeepCloneObjects
发表于 2010-10-18 11:00:00 | 显示全部楼层
 学习了。
但是这个方法类型为IdMapping的参数是起什么作用的?
英文解释如下,看不大明白。
IdMapping is used by the deep clone operation to map ObjectIds between original objects and their clones (using IdPairs).
There is no method provided to clear all entries in an instance of IdMapping. A new instance must be created for each use in a deep clone operation. Making IdMapping unique for each deep clone operation makes it possible to use the instance address as a distinguishing identifier in deep clone notification.
IdPair instances that have been added to the map are destroyed when the IDMapping instance is destroyed.
发表于 2010-10-18 19:21:00 | 显示全部楼层
IdMapping是源对象和目的对象的ID键值对的集合
发表于 2010-11-1 22:33:00 | 显示全部楼层
看不大明白
发表于 2011-1-10 16:04:12 | 显示全部楼层
深度克隆?
GMT+8, 2025-4-19 16:45 , Processed in 0.198851 second(s), 24 queries , Gzip On.
