;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;; ;;;;;;击块内一个图元(属性除外),如果再选择一个图元,则加入块;如果没有 ;;;;;;再选择一个图元,则所击块内图元将被删除。 (defun c:BlockObjectRA (/ BLOCKOBJECT SS) (setq BlockObject (lt:entsel "\n请击块中要删除的一个图元:" '((0 . "insert") (100 . "AcDbBlockReference")) (list "对象必须是块内对象,属性除外" "") ) ;_ end of lt:entsel ) ;_ end of setq (setq InsertPoint (cdr (assoc 10 (entget (car BlockObject)))))
(setq ss (entsel "\n选择图元则加入块,回车则删除所击的块中图元:"))
(if (and BlockObject ss) (BlockObjectAdd BlockObject ss) (BlockObjectRemove BlockObject) ) ;_ end of if
) ;_ end of defun
;;;说明:本函数用块名重新定义一个块,sst 为图元名表,blkn为已存在的块名. ;;;(实体表 块名 插入点) (defun make-a-block (sst blkn inp / BLKLST COUNT ENTLIST OSM TAG)
(setq osm (getvar "osmode")) ;获取用户捕捉 (setvar "osmode" 0)
(setq tag (getvar "ucsorg")) (setq inp (list (- (car inp) (car tag)) (- (cadr inp) (cadr tag)) (- (caddr inp) (caddr tag)) ) ;_ end of list ) ;_ end of setq (setq count 0) (setq blklst (ssadd)) (repeat (length sst) (setq entlist (entget (nth count sst))) (setq count (1+ count)) (entmake entlist) (ssadd (entlast) blklst) ) ;_ end of repeat (command "block" blkn "y" inp blklst "")
(setvar "osmode" osm) ) ;_ end of defun ;;;
;;;块内对象删除 (defun BlockObjectRemove (BlockObject / ENTLST FIRN FIRNLST SUBLST SUBNAME) (command "undo" "be")
(setq entlst (entget (car BlockObject))) (setq sublst (nentselp "" (cadr BlockObject))) (setq subname (car sublst)) ;块中一个元素,可以entget访问 (if (> (length sublst) 2) (progn (setq firn ;firn 为图元名 (cdr (assoc -2 ; (tblsearch "block" (cdr (assoc 2 entlst))) ;tblsearch+"block"+块名 ) ;_ end of assoc ) ;_ end of cdr ) ;_ end of setq (setq firnlst (list ())) (while firn (if (not (eq firn subname)) ;本句滤去选择的那一图元 (setq firnlst (append firnlst (list firn))) ) ;_ end of if (setq firn (entnext firn)) ) ;_ end of while此循环,不然整个块将删除;将块内各图元素(均可entget访问)列成表,前加nil
(make-a-block (cdr firnlst) (cdr (assoc 2 entlst)) ;块名 '(0 0 0) ) ;_ end of make-a-block
) ;_ end of progn (alert "\n所选择的可能是属性,删不了!") ) ;_ end of if (command "undo" "e") ) ;_ end of defun ;;;
;;;块内增加对象 (defun BlockObjectAdd (BlockObject ss / ENTLST FIRN FIRNLST) (command "undo" "be") (setq entlst (entget (car BlockObject))) (setq firn ;firn 为图元名 (cdr (assoc -2 ; (tblsearch "block" (cdr (assoc 2 entlst))) ;tblsearch+"block"+块名 ) ;_ end of assoc ) ;_ end of cdr ) ;_ end of setq (setq firnlst (list ())) (while firn (setq firnlst (append firnlst (list firn))) (setq firn (entnext firn)) ) ;_ end of while此循环,将块内各图元素(均可entget访问)列成表,前加nil (setq firnlst (append firnlst (list (car ss))))
(command "erase" ss "") (command "undo" "e") ) ;_ end of defun ;;;
(princ "\n本程序根据英雄无敌程序改编,块内加入图元不会改变块内属性值,但也有一个缺点,加入的图元离块很远,望高手解决之。")
