查看: 1509|回复: 3
[讨论] 我的程序运行出现错误
发表于 2010-10-20 13:33:00 | 显示全部楼层 |阅读模式
程序改了,可是还是出现错误,大虾们帮忙看看
(defun c:cccc()
(setq p1 (getpoint "\输入一个角点"))
(setq p3 (getcorner p1 "\输入第二个角点"))
(setq p2 (list (car p1) (cadr p3)))
(setq p4 (list (car p3) (cadr p1)))
(command "pline" p1 p2 p3 p4 "c")
(setq po1 (inters p1 p2 p3 p4))
(setq r (getpoint po1 "\n输入半径"))
(command "circle" po1 r )
发表于 2010-10-20 14:25:00 | 显示全部楼层
  1. (defun c:cccc ()
  2. (setq p1 (getpoint "\输入一个角点"))
  3. (setq p3 (getcorner p1 "\输入第二个角点"))
  4. (setq p2 (list (car p1) (cadr p3)))
  5. (setq p4 (list (car p3) (cadr p1)))
  6. (setvar "osmode" 0)
  7. (command "pline" p1 p2 p3 p4 "c")
  8. (setq po1 (inters p1 p3 p2 p4))
  9. (setq r (getdist po1 "\n输入半径"))
  10. (command "circle" po1 r)
  11. )
发表于 2010-10-20 17:08:00 | 显示全部楼层
小红同志第一次发帖,咱得顶啊,呵呵
 庆祝一下,
 楼主| 发表于 2010-10-20 17:23:00 | 显示全部楼层
快咯哦
GMT+8, 2025-2-23 20:01 , Processed in 0.228808 second(s), 25 queries , Gzip On.
