查看: 2098|回复: 1
[原创]用LISP去除VC的注释
发表于 2010-10-20 16:49:00 | 显示全部楼层 |阅读模式
这段代码是LISP程序。不知发在哪个版上合适,选发到这里。
功能是:删除VC里面的注释。
(defun c:ezx(/)
  (if(SETQ SG(GETFILED "选择Cpp文件" "C:\\" "cpp" 8))(progn
  (SETQ NB(strcat(vl-filename-directory sg)(STRCAT"\\"(vl-filename-base SG)"-New")(vl-filename-extension sg)))
  (setq file1 (open SG "R"))
  (setq file2 (open NB "W"))
  (while(setq re1(read-line file1))
    (if(not(equal re1 ""))
 (setq n(vl-string-search "//"re1))
    (cond
      ((> n 0)
 (setq re1(strcat "\n"(substr re1 1 (vl-string-search "//"re1))))
       ;(setq re1"asdfas/*123*/pijl/*8965*/")
       (while(and(setq a1 (vl-string-search "/*"re1))
   (setq a2 (vl-string-search "*/"re1))
  (setq re1(strcat(substr re1 1 a1)(substr re1 (+ a2 3)(strlen re1))))
       (princ re1 file2)
      ((not n)
 (setq re1(strcat "\n"re1))
       (princ re1 file2)
  (close file1)
  (close file2)
   (setq file1 (open  NB"R"))
  (setq file2 (open SG "W"))
    (princ re1 file2))
  (close file1)
  (close file2)
      (vl-file-delete NB)
发表于 2010-12-11 20:31:28 | 显示全部楼层
有创意哦
但是注释也是有用的
某些时候还是可用这程序
GMT+8, 2025-4-22 12:19 , Processed in 0.183163 second(s), 24 queries , Gzip On.
