查看: 2287|回复: 4
[基础] [求助]LISP提取三维实体的体积
发表于 2010-10-23 13:51:00 | 显示全部楼层 |阅读模式
怎么搞,实体的体积啊,entget 没有要用的东西,用massprop怎么取啊!!帮帮忙啊
发表于 2010-10-23 22:05:00 | 显示全部楼层
(defun c:tj()
    (while (setq ent (car (entsel "\n选择三维实体:")))
        (redraw ent 3)
         (setq vob (vlax-ename->vla-object ent)
        v   (vl-catch-all-apply 'vla-get-Volume (list vob))
         (if (vl-catch-all-error-p v)
      (alert "所选取的图元不具有体积属性!")
      (alert (strcat "体积=" (rtos v)))
        (redraw ent 4)
 楼主| 发表于 2011-10-15 08:59:35 | 显示全部楼层
非常感谢,我试试
发表于 2024-11-9 19:39:14 | 显示全部楼层
yshf 发表于 2010-10-23 22:05
(defun c:tj()    (while (setq ent (car (entsel "\n选择三维实体:"))) &nbs ...
这个代码让计算出的结果像前移动九位书写到CAD绘图区,后面加上单位立方米,感谢大佬指点
GMT+8, 2025-4-9 09:11 , Processed in 0.167188 second(s), 26 queries , Gzip On.
