查看: 6656|回复: 11
请帮个忙
发表于 2002-5-27 23:07:00 | 显示全部楼层 |阅读模式
我有一个原来在R12下用的lisp小程序,现在想用在R14下,可是不能用。是什么原因?
发表于 2002-5-27 23:18:00 | 显示全部楼层
贴出来吧,大家会帮你改好
 楼主| 发表于 2002-5-28 00:00:00 | 显示全部楼层
help
请问如何贴
发表于 2002-5-28 00:03:00 | 显示全部楼层
用记事本打开相应的LSP文件,复制后粘贴到这里就行
 楼主| 发表于 2002-5-28 00:06:00 | 显示全部楼层
全是乱码
AutoCAD PROTECTED LISP file
aI鰣w沋扚浣$k?,x邿L氩k?R总諎y乸?奚鰛q吗弢宬鰩i峬縭您哸?b?O騹!*3z汣宮?B岘/~怤
发表于 2002-5-28 00:19:00 | 显示全部楼层
晕,要解密才行,你把文件压缩后贴出来(用顶上的回复贴子功能),我来解决
 楼主| 发表于 2002-5-28 00:32:00 | 显示全部楼层
thanks
 楼主| 发表于 2002-5-28 06:36:00 | 显示全部楼层
谢谢
发表于 2002-5-28 10:06:00 | 显示全部楼层
你好管理員,請問怎么才能將全是亂碼的文件解密
发表于 2002-5-28 22:29:00 | 显示全部楼层
解密后的程序如内,大家看看吧
(defun cht_Main        (/             sset         opt             ssl
                 nsset             temp         unctr             ct_ver
                 sslen             style         hgt             rot
                 txt             ent         loc             loc1
                 just-idx    justp         justq             orthom
                 cht_ErrorHandler         cht_OrgError
                 cht_OrgCmdecho                 cht_OrgTexteval
                 cht_OrgHighlight
  (setq ct_ver "2.00")
  (defun cht_ErrorHandler (s)
    (if        (/= s "Function cancelled")
      (if (= s "quit / exit abort")
        (princ (strcat "\n错误: " s))
    (eval (read U:E))
    (if        cht_OrgError
      (setq *error* cht_OrgError)
    (if        temp
      (redraw temp 1)
    (ai_undo_off)
    ;; restore undo state
    (if        cht_OrgCmdecho
      (setvar "cmdecho" cht_OrgCmdecho)
    (if        cht_OrgTexteval
      (setvar "texteval" cht_OrgTexteval)
    (if        cht_OrgHighlight
      (setvar "highlight" cht_OrgHighlight)
  (if *error*
    (setq cht_OrgError *error*
          *error*      cht_ErrorHandler
    (setq *error* cht_ErrorHandler)
  (setq        U:G "(command \"_.undo\" \"_group\")"
        U:E "(command \"_.undo\" \"_en\")"
  (ai_undo_on)
  ;; enable undo
  (setq cht_OrgCmdecho (getvar "cmdecho"))
  (setq cht_OrgHighlight (getvar "highlight"))
  (setvar "cmdecho" 0)
  (princ (strcat "\n 改变文本, 版权号 "
                 ct_ver
                 ", 版权1997 。Autodesk, Inc."
  (prompt "\n选择要改变的注释.")
  (setq sset (ai_aselect))
  (if (null sset)
      (princ "\n没有选择物体.")
      (exit)
  (setq        ssl   (sslength sset)
        nsset (ssadd)
  (if (> ssl 25)
    (princ "\n 检验选择的物体...")
  (while (> ssl 0)
    (setq temp (ssname sset (setq ssl (1- ssl))))
    (if        (or
          (= (cdr (assoc 0 (entget temp))) "TEXT")
          (= (cdr (assoc 0 (entget temp))) "ATTDEF")
          (= (cdr (assoc 0 (entget temp))) "MTEXT")
      (ssadd temp nsset)
  (setq        ssl   (sslength nsset)
        sset  nsset
        unctr 0
  (print ssl)
  (princ " 发现注释(nnotation objects found).")
  (setq opt T)
  (while (and opt (> ssl 0))
    (setq unctr (1+ unctr))
    (command "_.UNDO" "_GROUP")
    (initget
      "Location Justification Style Height Rotation Width Text Undo"
    (setq opt (getkword
                "\n高H/对齐J/定位L/旋转R/类型S/文字T/回退U/宽W: "
    (if        opt
      (cond
        ((= opt "Undo")
         (cht_Undo)
        ((= opt "Location")
         (cht_Location)
        ((= opt "Justification")
         (cht_Justification)
        ((= opt "Style")
         (cht_Property "Style" "新类型名" 7)
        ((= opt "Height")
         (cht_Property "Height" "新高度" 40)
        ((= opt "Rotation")
         (cht_Property "Rotation" "新的旋转角度" 50)
        ((= opt "Width")
         (cht_Property "Width" "新宽度" 41)
        ((= opt "Text")
         (cht_Text)
      (setq opt nil)
    (command "_.UNDO" "_END")
  (if cht_OrgError
  (eval (read U:E))
  (ai_undo_off)
  (if cht_OrgTexteval
  (if cht_OrgCmdecho
(defun cht_Undo        ()
  (if (not nop)
    (dscprinc)
  (if (> unctr 1)
      (command "_.UNDO" "2")
      (setq unctr (- unctr 2))
      (princ "\n没有操作进行回退. ")
      (setq unctr (- unctr 1))
(defun cht_Location ()
  (if (not nop)
    (dscprinc)
  (setq        sslen (sslength sset)
        style ""
        hgt   ""
        rot   ""
        txt   ""
  (command "_.CHANGE" sset "" "")
  (while (> sslen 0)
    (setq ent (entget (ssname sset (setq sslen (1- sslen))))
          opt (list (cadr (assoc 11 ent))
                    (caddr (assoc 11 ent))
                    (cadddr (assoc 11 ent))
    (prompt "\n新的文字位置: ")
    (command pause)
    (if        (null loc)
      (setq loc opt)
    (command style hgt rot txt)
  (command)
(defun cht_Justification ()
  (if (not nop)
    (dscprinc)
  (initget
    "TL TC TR ML MC MR BL BC BR Align Center Fit Left Middle Right ?"
  (setq sslen (sslength sset))
  (setq        justp
         (getkword
           "\n 排列A/拟合F/中心C/左L/中M/右R/左上TL/左中TC/右上TR/左中ML/正中MC/右中MR/左下BL/中下BC/右下BR/<?>: "
  (cond
    ((= justp "Left")
     (setq justp 0
           justq 0
           just-idx 4
    ((= justp "Center")
     (setq justp 1
           justq 0
           just-idx 5
    ((= justp "Right")
     (setq justp 2
           justq 0
           just-idx 6
    ((= justp "Align")
     (setq justp 3
           justq 0
           just-idx 1
    ((= justp "Fit")
     (setq justp 5
           justq 0
           just-idx 1
    ((= justp "TL")
     (setq justp 0
           justq 3
           just-idx 1
    ((= justp "TC")
     (setq justp 1
           justq 3
           just-idx 2
    ((= justp "TR")
     (setq justp 2
           justq 3
           just-idx 3
    ((= justp "ML")
     (setq justp 0
           justq 2
           just-idx 4
    ((= justp "Middle")
     (setq justp 4
           justq 0
           just-idx 5
    ((= justp "MC")
     (setq justp 1
           justq 2
           just-idx 5
    ((= justp "MR")
     (setq justp 2
           justq 2
           just-idx 6
    ((= justp "BL")
     (setq justp 0
           justq 1
           just-idx 7
    ((= justp "BC")
     (setq justp 1
           justq 1
           just-idx 8
    ((= justp "BR")
     (setq justp 2
           justq 1
           just-idx 9
    ((= justp "?") (setq justp nil))
    (T (setq justp nil))
  (if justp
      ;; Process them...
      (while (> sslen 0)
        (setq ent (entget (ssname sset (setq sslen (1- sslen)))))
        (cond
          ((= (cdr (assoc 0 ent)) "MTEXT")
           (setq ent (subst (cons 71 just-idx) (assoc 71 ent) ent))
          ((= (cdr (assoc 0 ent)) "TEXT")
           (setq ent (subst (cons 72 justp) (assoc 72 ent) ent)
                 opt (trans (list (cadr (assoc 11 ent))
                            (cdr (assoc -1 ent))
                            ;; from ECS
                            1
                     ;; to current UCS
           (setq ent (subst (cons 73 justq) (assoc 73 ent) ent))
           (cond
             ((or (= justp 3) (= justp 5))
              (prompt "\n新的文字对齐点(New text alignment points): ")
              (if (= (setq orthom (getvar "orthomode")) 1)
                (setvar "orthomode" 0)
              (redraw (cdr (assoc -1 ent)) 3)
              (initget 1)
              (setq loc (getpoint))
              (initget 1)
              (setq loc1 (getpoint loc))
              (redraw (cdr (assoc -1 ent)) 1)
              (setvar "orthomode" orthom)
              (setq ent (subst (cons 10 loc) (assoc 10 ent) ent))
              (setq ent (subst (cons 11 loc1) (assoc 11 ent) ent))
             ((or (/= justp 0) (/= justq 0))
              (setq loc (getpoint opt))
              (if (null loc)
                (setq loc opt)
                (setq loc (trans loc 1 (cdr (assoc -1 ent))))
              (setq ent (subst (cons 11 loc) (assoc 11 ent) ent))
        (entmod ent)
      ;; otherwise list options
      (textpage)
      (princ "\n      对齐位置设置:\n")
      (princ "\t  左上TL     中上TC      右上TR\n")
      (princ "\t  左中ML     正中MC      右中MR\n")
      (princ "\t  左下BL     中下BC      右下BR\n")
      (princ "\t  左Left     中Center    右Right\n")
      (princ "\t  对齐Align  中Middle    拟合Fit\n")
      (princ "\n回车继续: ")
      (grread)
      (princ
        "\r                                                            "
      (graphscr)
  (command)
(defun cht_Text        (/ ans)
  (if (not nop)
    (dscprinc)
  (initget "Globally Individually Retype")
  (setq        ans
         (getkword
           "\n 发现并替换文字.  单个(Individually)/重复(Retype)/<全部(Globally)>:"
  (setq cht_OrgTexteval (getvar "texteval"))
  (setvar "texteval" 1)
  (cond
    ((= ans "Individually")
       (initget "Yes No")
       (setq ans (getkword "\n在对话框中修改文字? <Yes>:"))
     (while (> sslen 0)
       (redraw (setq sn (ssname sset (setq sslen (1- sslen)))) 3)
       (setq ss (ssadd))
       (ssadd (ssname sset sslen) ss)
       (if (= ans "No")
         (cht_Edit ss)
         (command "_.DDEDIT" sn "")
       (redraw sn 1)
    ((= ans "Retype")
     (while (> sslen 0)
       (prompt (strcat "\nOld text: " (cdr (assoc 1 ent))))
       (setq nt (getstring T "\nNew text: "))
       (if (> (strlen nt) 0)
         (entmod (subst (cons 1 nt) (assoc 1 ent) ent))
    (T
     (cht_Edit sset)
     ;; Change all
(defun C:CHGTEXT () (cht_Edit nil))
(defun cht_Edit        (objs        /      last_o tot_o  ent    o_str  n_str
                 st        s_temp n_slen o_slen si            chf           chm
                 cont        ans    class
  (if (not nop)
    (dscprinc)
  (if (null objs)
    (setq objs (ssget))
  (setq chm 0)
  (if objs
      ;; If any objects selected
      (if (= (type objs) 'ENAME)
          (setq ent (entget objs))
          (princ (strcat "\n存在的字符串: " (cdr (assoc 1 ent))))
        (if (= (sslength objs) 1)
            (setq ent (entget (ssname objs 0)))
      (setq o_str (getstring "\n 匹配字符串  : " t))
      (setq o_slen (strlen o_str))
      (if (/= o_slen 0)
          (setq n_str (getstring "\n 新字符串     : " t))
          (setq n_slen (strlen n_str))
          (setq        last_o 0
                tot_o  (if (= (type objs) 'ENAME)
                         1
                         (sslength objs)
          (while (< last_o tot_o)
            (setq class
                   (cdr
                     (assoc 0 (setq ent (entget (ssname objs last_o))))
            (if        (or (= "TEXT" class)
                    (= "MTEXT" class)
                (setq chf nil
                      si  1
                (setq s_temp (cdr (assoc 1 ent)))
                (while (= o_slen
                          (strlen (setq st (substr s_temp si o_slen)))
                  (if (= st o_str)
                      (setq s_temp (strcat
                                     (if (> si 1)
                                       (substr s_temp 1 (1- si))
                                     n_str
                                     (substr s_temp (+ si o_slen))
                      (setq chf t)
                      ;; Found old string
                      (setq si (+ si n_slen))
                    (setq si (1+ si))
                (if chf
                    ;; Substitute new string for old
                    (entmod (subst (cons 1 s_temp) (assoc 1 ent) ent))
                    (setq chm (1+ chm))
            (setq last_o (1+ last_o))
  (if (/= (type objs) 'ENAME)
    (if        (/= (sslength objs) 1)
      (princ
        (strcat (rtos chm 2 0) " 多行文字改变(text lines changed).")
  (terpri)
(defun cht_Property (typ prmpt fld / temp ow nw        ent tw sty w hw        lw sslen
                     n sn ssl)
  (if (not nop)
    (dscprinc)
  (if (= (sslength sset) 1)
    ;; Special case if there is only
    (cht_ProcessOne)
      (cht_SetPrompt)
      (if (= nw "List")
        (cht_ProcessList)
        (if (= nw "Individual")
          (cht_ProcessIndividual)
          (if (= nw "Select")
            (cht_ProcessSelect)
              (if (= typ "Rotation")
                (setq nw (* (/ nw 180.0) pi))
              (if (= (type nw) 'STR)
                (if (not (tblsearch "style" nw))
                    (princ (strcat nw ": Style not found. "))
                  (cht_ProcessAll)
                (cht_ProcessAll)
(defun cht_ProcessAll (/ hl temp)
  (if (not nop)
    (dscprinc)
  (setq hl (getvar "highlight"))
  (setvar "highlight" 0)
  (while (> sslen 0)
    (setq temp (ssname sset (setq sslen (1- sslen))))
    (entmod (subst (cons fld nw)
                   (assoc fld (setq ent (entget temp)))
                   ent
  (setvar "highlight" hl)
(defun cht_ProcessOne ()
  (if (not nop)
    (dscprinc)
  (setq temp (ssname sset 0))
  (setq ow (cdr (assoc fld (entget temp))))
  (if (= opt "Rotation")
    (setq ow (/ (* ow 180.0) pi))
  (redraw (cdr (assoc -1 (entget temp))) 3)
  (initget 0)
  (if (= opt "Style")
    (setq nw (getstring (strcat prmpt " <" ow ">: ")))
    (setq nw (getreal (strcat prmpt " <" (rtos ow 2) ">: ")))
  (if (or (= nw "") (= nw nil))
    (setq nw ow)
  (redraw (cdr (assoc -1 (entget temp))) 1)
  (if (= opt "Style")
    (if        (null (tblsearch "style" nw))
                     ent
                   ent
(defun cht_SetPrompt ()
  (if (not nop)
    (dscprinc)
  (if (= typ "Style")
      (initget "Individual List New Select ")
      (setq nw
             (getkword
               (strcat "\n 单个Individual/列表List/选择类型Select style/<"
                       prmpt
                       " 对所有的文字"
      (if (or (= nw "") (= nw nil) (= nw "Enter"))
                                    " 对所有的文字"
      (initget "List Individual" 1)
      (setq nw (getreal        (strcat        "\n单个Individual/列表List/<"
                                prmpt
                                " 对所有的文字"
(defun cht_ProcessList ()
  (if (not nop)
    (dscprinc)
  (setq unctr (1- unctr))
  (setq tw 0)
  (while (> sslen 0)
    (if        (= typ "Style")
        (if (= tw 0)
          (setq tw (list (cdr (assoc fld (entget temp)))))
            (setq sty (cdr (assoc fld (entget temp))))
            (if        (not (member sty tw))
              (setq tw (append tw (list sty)))
        (setq tw (+ tw (setq w (cdr (assoc fld (entget temp))))))
        (if (= (sslength sset) (1+ sslen))
          (setq        lw w
                hw w
        (if (< hw w)
          (setq hw w)
        (if (> lw w)
          (setq lw w)
    (setq tw (* (/ tw pi) 180.0)
          lw (* (/ lw pi) 180.0)
          hw (* (/ hw pi) 180.0)
  (if (= typ "Style")
      (princ (strcat "\n" typ "(s) -- "))
      (princ tw)
    (princ (strcat "\n"
                   typ
                   " -- 最小Min: "
                   (rtos lw 2)
                   "\t 最大Max: "
                   (rtos hw 2)
                   "\t 中间Avg: "
                   (rtos (/ tw (sslength sset)) 2)
(defun cht_ProcessIndividual ()
  (if (not nop)
    (dscprinc)
  (while (> sslen 0)
    (initget 0)
    (if        (= typ "Style")
        (setq nw (getstring (strcat "\n" prmpt " <" ow ">: ")))
        (setq nw (getreal (strcat "\n" prmpt " <" (rtos ow 2) ">: ")))
      (setq nw ow)
                   ent
(defun cht_ProcessSelect ()
  (if (not nop)
    (dscprinc)
  (princ "\n 查找何种类型名?  <*>: ")
  (setq        sn    (xstrcase (getstring))
        n     -1
        nsset (ssadd)
        ssl   (1- (sslength sset))
  (if (or (= sn "*") (null sn) (= sn ""))
    (setq nsset        sset
          sn        "*"
    (while (and sn (< n ssl))
      (setq temp (ssname sset (setq n (1+ n))))
      (if (= (cdr (assoc 7 (entget temp))) sn)
        (ssadd temp nsset)
  (princ (strcat "\n类型: " sn))
  (print (setq ssl (sslength nsset)))
  (princ "发现.")
(cond
  ((and ai_dcl (listp ai_dcl)))                ; it's already loaded.
  ((not (findfile "ai_utils.lsp"))        ; find it
   (ai_abort "CHT" nil)
  ((eq "failed" (load "ai_utils" "failed")) ; load it
(if (not (ai_acadapp))
(defun c:cht () (cht_Main))
(princ "\n\tCHT 命令调入.")
GMT+8, 2025-6-2 08:30 , Processed in 0.191907 second(s), 26 queries , Gzip On.
