查看: 1458|回复: 4
[求助]表的处理
发表于 2010-11-9 13:42:00 | 显示全部楼层 |阅读模式
请教大家,我要怎样才能从这个表
'((DWGNO "MOLD1")
(3HRC "HRC 60-62")
(3MAT "SKD11")
(3THICK 40)
(2HRC "HRC 56-58")
(2MAT "Cr12")
(2THICK 30)
(1HRC "/")
(1MAT "45#")
(1THICK 20)
(MBNUMBER 3)
(MBLIST "3#2#1#")
拆分得到下面的表呢
(setq mb_list   '("1"         "2"                    "3") )
(setq thick_list '( 20         30                    40))
(setq mat_list  '( "45#"   "Cr12"              "SKD11" ))
(setq hrc_list   '("/"        "HRC 56-58"     "HRC 60-62))
发表于 2010-11-9 16:03:00 | 显示全部楼层
  1. (setq lst '((DWGNO "MOLD1")
  2. (3HRC "HRC 60-62") (3MAT "SKD11") (3THICK 40) (2HRC "HRC 56-58")(2MAT "Cr12")
  3. (2THICK 30) (1HRC "/")   (1MAT "45#")  (1THICK 20) (MBNUMBER 3) (MBLIST "3#2#1#")
  4.       )
  5. )
  6. (mapcar '(lambda(x)(cadr (assoc x lst))) '(1THICK 2THICK 3THICK))
  7. (mapcar '(lambda(x)(cadr (assoc x lst))) '(1MAT 2MAT 3MAT) )
  8. (mapcar '(lambda(x)(cadr (assoc x lst))) '(1HRC 2HRC 3HRC ) )
  9. (setq txt (cadr (assoc 'MBLIST lst)))
  10. (while (vl-string-search "#" txt )
  11.   (setq txt (vl-string-subst "" "" "#" txt))
  12. )
  13. (setq txt (read (strcat "(""   txt "")")))
下面的自己处理吧.
 楼主| 发表于 2010-11-9 16:33:00 | 显示全部楼层
谢谢,真利害,再次请教,要是这一句(mapcar '(lambda(x)(cadr (assoc x lst))) '(1MAT 2MAT 3MAT) )里面的'(1MAT 2MAT 3MAT) 改成lst的第几项的cadr如'(第8项 第5项 第2项)要怎么写呢,因为我里面的'(1MAT 2MAT 3MAT)是变量
发表于 2010-11-9 16:44:00 | 显示全部楼层
自己看看mapcar 的语法.
(mapcar '(lambda(x)(cadr (nth x lst))) '(8 5 2))
 楼主| 发表于 2010-11-10 09:25:00 | 显示全部楼层
好的,谢谢xshrimp
GMT+8, 2025-5-31 15:13 , Processed in 0.252993 second(s), 25 queries , Gzip On.
