请教各位大侠,如下程序- (defun c:tt(/ regex lst) (vl-load-com) (setq regex (vlax-create-object "Vbscript.RegExp")) (vlax-put-property regex "IgnoreCase" 0) (vlax-put-property regex "Global" 1) ; (vlax-put-property regex "Pattern" ".*%%P([\d]+[\\\\.]?[\d]*).*") (setq string "<>%%P0.05gd") (setq result (vlax-invoke-method regex "Replace" string "$1")) (princ result) (vlax-release-object regex) )
在AutoCAD中,总是输出"",
但是我在正则表达式测试工具中都是输出0.05请教大侠们原因,谢谢。
