查看: 1504|回复: 4
保存和恢复图层设置
发表于 2010-11-25 00:33:00 | 显示全部楼层 |阅读模式
帮助文件中的保存恢复图层设置是做什么用的,一般用在什么情况下?
发表于 2010-11-25 09:47:00 | 显示全部楼层
哪里的,你直接把相关的内容贴过来吧
 楼主| 发表于 2010-11-25 12:30:00 | 显示全部楼层
  1. public static void SaveLayerColorAndLinetype()
  2. {
  3. document
  4. Document acDoc = Application.DocumentManager.MdiActiveDocument;
  5. LayerStateManager acLyrStMan;
  6. acLyrStMan = acDoc.Database.LayerStateManager;
  7. string sLyrStName = "ColorLinetype";
  8. if (acLyrStMan.HasLayerState(sLyrStName) == false)
  9. {
  10. acLyrStMan.SaveLayerState(sLyrStName,
  11. LayerStateMasks.Color |
  12. LayerStateMasks.LineType,
  13. ObjectId.Null);
  14. }
  15. }
  16. public static void RestoreLayerState()
  17. {
  18. document
  19. Document acDoc = Application.DocumentManager.MdiActiveDocument;
  20. LayerStateManager acLyrStMan;
  21. acLyrStMan = acDoc.Database.LayerStateManager;
  22. string sLyrStName = "ColorLinetype";
  23. if (acLyrStMan.HasLayerState(sLyrStName) == true)
  24. {
  25. acLyrStMan.RestoreLayerState(sLyrStName,
  26. ObjectId.Null,
  27. 1,
  28. LayerStateMasks.Color |
  29. LayerStateMasks.LineType);
  30. }
  31. }
复制代码
发表于 2010-11-25 12:42:00 | 显示全部楼层
临时更改图层用途的时候可能会用到
不过如果正规作图很少有这种需求
 楼主| 发表于 2010-11-25 20:00:00 | 显示全部楼层
谢谢...
GMT+8, 2025-5-12 11:20 , Processed in 0.172170 second(s), 23 queries , Gzip On.
